Jaguar Remote app
Received 3,259 Likes
I think you are out of luck, I believe it wasn't available on/for the F-Type until at least the 2016 model year.
Then im definitely out of luck.
I have the remote start and lock/unlock function on my 2016 up until recently. Not sure if it's an iOS issue but although I get the status and location update, journeys have stopped updating and the remote unlock/lock spins and times out telling me there is a network connection problem. Jaguar corporate said I should contact my dealer who said they didn't know of any known issues but would take the car in for review if the telematics module needed update. Good old Jaguar Austin, see you at the end of January....
I've been using the remote start on my MY18 recently now it's got cold here. It frequently pops up a message saying I'm in a poor signal area and should move the car, but the function still works. Only downside is that when the car goes into deep sleep (after 2 days, not 4 as advertised) all bets are off. I've found that using the fob to unlock and relock the car does the trick to wake it up, but that obviously only works within fob range. I'm using the app on an Android 'phone.
I drive it only on weekends, so i guess that would have been a constant issue.
Any known workaround to get this working for the older models?
The app does have a Wakeup option that enables you to set a date on which the car will come out of its slumber. Of course, you have to set it while the car is still contactable.
Bonz (12-20-2019)
Bonz (12-20-2019)
The following 2 users liked this post by eeeeek:
Bonz (12-21-2019),
JC_In_83814 (02-08-2020)
must have been around 80-100m , and it blinked the indicators ! Phone would not have managed, two floors down-under the ground..
Bonz (12-22-2019)
I used the 'beep & flash' to scare away a rusty old van that was about to park in front of my car, in a gap I could see was far to small.
I was in a restaurant in Spain. looking out of the window, keeping an eye on the car. The guy drives past, starting to back up [ in line ].
So when he is starting to do this I 'beep & flash' through the phone, which is no exact science [ can take up to a minute to actually happen].
But it beeped when it was about a meter from the front. The guy pulled away and didn't return..
Bonz (12-22-2019)
Originally Posted by Nznoonee
Been using the app every day. Sometimes for remote start, sometimes for checking the position to understand whether the car was towed lol.
Also when I'm not around it helps to open the trunk or doors if someone needs it, used this feature at least twice
Worse : it would say 'window open, doors unlocked, alarm off' .. ..while everything was closed and double locked !
I informed my dealer. What if the car is stolen and this wrong data ends up with the insurance ???
