January 17, having C Quartz applied to the car.... how has anyone's experience
There was not a detailer in my area that offered C Quartz so I went with Ceramic Pro and I am very pleased with it. During the first rain we had after it was applied, the water rolled off in sheets while the remainder beaded and then just disappeared. Not one spot. You could not even tell it had rained. The true test will come in May when we are inundated by thousands of Love Bugs that stick to the front of the car like glue.
Dealer is trying to sell me the X-Pack interior and exterior treatment from MotorOne X-PACK - Protection in Xtreme Situations » MotorOne
I've always been highly skeptical about protection products sold by dealers. Does anyone have any thoughts on this product, or protection products in general?
OzRisk (01-08-2015)
Oz, I'm with you and always been a skeptic. I hand-wash frequently, use clean micro-fiber towels, and wax often enough to keep water beading up. My cars have always retained that new car look many years later without using them. However, the majority of active participants here swear by them.
The following 2 users liked this post by Unhingd:
OzRisk (01-08-2015),
sherbercars (01-09-2015)
I actually do high-end paint correction & detailing, so I speak from a bit of experience here...
When it comes to protecting the paint finish on your vehicle, you essentially have three options:
Wax, sealant or coating.
What most people don't realize is - the shine/reflection that you see is achieved from the prep (washing, claying, polishing, etc.) prior to applying the LSP (last step product)
90% of the shine comes from the prep, while the other 10% is LSP
Waxes
Generally defined as any product that contains a natural or synthetic waxy ingredients that are intended to protect the paint and/or add beauty to the paint. These types traditional waxes will wear off under normal wear-n-tear, repeated washings and exposure to the environment.
Paint Sealants
Generally defined as any protection product that contains man-made or synthetic ingredients that are intended to protect the paint and/or add beauty to the paint. These traditional sealants will wear off under normal wear-n-tear, repeated washing and exposure to the environment.
Coatings
Generally defined as any paint protection product that contains man-made or synthetic protection ingredients that are intended to permanently bond to the paint to both provide a barrier-coating of protection as well as create a clear, high gloss finish. The products available in this category are considered permanent coatings because like your car's paint, they cannot be removed unless you purposefully remove them or you purposefully neglect them.
For those that enjoy washing and waxing, a coating makes no sense - If you don't wash often, and never want to wax/seal, a coating makes sense.
I personally don't care for coatings.
Waxes
Paint Sealants
Coatings
The following 7 users liked this post by Joz132:
DJS (01-08-2015),
F-TypeRookie (01-08-2015),
Foosh (01-08-2015),
sherbercars (01-09-2015),
and 2 others liked this post.
Waxes
Paint Sealants
Coatings
Waxes
Paint Sealants
Coatings
I agree 100%
It is all in the prep.
I too do detailing and I prefer for a LSP is to use Menzerna Power Lock
2 coats, 3 hour cure in between coats. should last 3-6 months depending on what you use to wash your car.
If you hand wash and use the cheap car wash soap from the major brands. This will strip the sealant. If you use a good quality car wash shampoo that is gentle you should get 6 months minimum.
Joz132 (01-08-2015)
Waxes
Paint Sealants
Coatings
Waxes
Paint Sealants
Coatings
Keep in mind, the coating will suffer the cosmetic damage of these things, and hopefully leave the clear-coat underneath it unscathed.
You will still get swirls, scratches and imperfections - they would have to be buffed out and the coating re-applied.
...hope that makes sense
sherbercars (01-10-2015)
