John Hennessey mods a 2017 Jag R series
John Hennessey reviews the modified Jaguar.
http://youtu.be/u7GTeeWCgkM
Power:
• 616 bhp @ 6,500 rpm *
• 597 lb-ft torque @ 4,200 rpm *
Performance:
• 0-60 mph: 3.2 sec.
• 1/4 mile: 11.4 sec. @ 124 mph
Includes:
• Custom Software Upgrade Tuning
• High Flow Air Filter
• Supercharger Pulley Upgrade
• Professional Installation
• Dyno Tuning & Road Testing
• Serial-Numbered Dash Plaque
• Serial-Numbered Engine Plaque
• Hennessey Exterior Badging
• 3 Year / 36,000 Mile Limited Warranty
* Estimated power ratings at the engine. Actual power will be measured at the rear wheels, before and after the upgrades are installed and tuned. Rear wheel horsepower and torque figures are approximately 15-20% lower than the factory published power figures which are measured at the crankshaft on an engine dyno.
Power:
Performance:
Includes:
When I checked a couple years ago, they wanted $13k for that package. Of that, I estimated they are charging $10k of that for the plaques, logo and warranty. This is just one example of what's been written about Hennessey: http://www.google.com/url?sa=t&rct=j...KoV8vUFlQNSFQQ
Probably would just be easier to move the temp probe. We're trying to address this problem with one step colder spark plugs, which I've already installed. However the other issue I'm having is I keep blowing the tires off the thing. The stock Pirellis start to slip at the top of 1st and 2nd and ESC cuts power on 50% of my runs. Upgraded tires are in order.
Re tires, I can't seem to burn through the ones on my car fast enough. I look forward to slapping some good rubber on this car. I can't go full throttle in second gear at all right now.
Fair enough re the temp prob. With the M156 motor in the AMGs, people modding would remove the cats (good god they would get loud) and use software to prevent codes. The cats were rather restrictive on those cars. More than half, id guess, would take out the secondary cats (because there was no O2 sensor behind them, and thus no need to do software). I figured it would be a simple fix to the overheating problems in the X152.
Michelin PS4S would be the likely choice. Going to a cup tire probably would be unnecessary.
