Jump starting?
On a related note.. Graham has included a link to the Owner's Manual in the 'How To' Guides thread. You might want to download a copy for easy reference:
http://www.mediafire.com/view/d0vr8q...i6b/US_101.pdf
I believe it just has the 2014 US and UK versions, but you can get other years at JagDocs for under $5:
http://www.jagdocs.com/index.php?mai...&cPath=142_154
Good to know about the emergency release, I hadn't picked that up, I thought it was just for the brake as that is the case for my Land Rover.
Yes connecting a jump starter to the underhood connections will give you enough power to open the boot/trunk. I have a portable jump starter but the car drained it dead without starting the car. I had to connect another car by jumper leads directly to the battery in the boot and leave it connected for quite a while before I could build up enough charge to start the car.
If you're stranded somewhere, with no jumper cables, or not in a position to hook-up to another running vehicle, you can do it safely by disconnecting the battery cables, and then hooking up your starter. That should quickly put enough charge into the battery to get going, unless the battery is defective and won't accept any charge.
Kitesurfer (06-08-2016)
#28
#30
#32
Mbourne (06-09-2016)
#33
with boosting vehicles.
As for the starter packs, I wonder if they output voltage in
excess of 15 volts. If not, then I cannot see how hooking it
up in the usual manner parallel to the circuit could result
in any over voltage. Perhaps the risk is in in-rush current,
but circuits only draw as much as they need and no more.
#34
I actually had to re-read the passage and I'm not unfamiliar
It's probably not a problem in the vast majority of cases just to slap on the jumper cables and crank, but it's also not a big deal to disconnect a battery cable before hooking up the jumper cables to the battery as an added precaution.
#35
A disclaimer: the manual discourages hooking anything up straight to the battery, since the battery gives off hydrogen, etc. as it charges, which could be ignited when you disconnect the cables.
Most people know this, of course, but if you don't know what you're doing.... don't try it. And, good ventilation is your friend.
#36
Unhingd (06-08-2016)
#38
o1xjr
05-27-2016 09:29 AM
