K & N air filter
Hi guys,
Has anyone swapped out the car's stock air filter and replaced it with a free flow air filter, K & N or similar type of filter.
If yes, was it worth doing? My opinion is, it's not worth putting an oiled filter as it might mess up the MAF. Am I wrong?
Last, is there a dry non oiled high performance air filter on the market, better than the OEM filter.
+1. And the power increase of "free-flow" filter media has been debunked. The design of the intake tubing and flow through the filter housing (maintaining laminar flow) has a far greater impact on power production.
I'm with the others......no K&N's for me. I've had in depth discussions on this topic on several motorcycle forums as well as the turbodiesel registry and the short version is I won't use them, and I'd especially avoid them on engines used in dirty environments or forced induction engines.
Dave
Dave
The theory on the dry vs oiled is that the oil traps more dust particles. The oil isn't really an extremely wet type so no it won't go through the intake system and clog up the MAF. They do need to be "recharged", but not that often. And no they won't provide any real additional power; it just comes down to the filtration performance.
https://www.bobistheoilguy.com/airfilter/airtest1.htm
https://www.bobistheoilguy.com/airfilter/airtest3.htm
Filtration tests have shown the ineffectiveness of the K&N filters:
Received 2,263 Likes
SinF (12-04-2016)
I haven't followed K&N specifically, but I spent a lot of time in the import modification realm during the 90's when that was "the thing". I've seen all the tests for an against (whether it's filtration or dyno) for various intake manufacturers over the years (using various filter types). However, I've yet to see an engine failure directly related to any specific filter type.
