Key Fob Not Syncing
Old 01-28-2017, 12:51 PM
zmoothg's Avatar
Originally Posted by Unhingd
Just for grins, try changing the fob battery.
Yeah that's the first thing I tried. No luck, same issue.
Old 01-28-2017, 02:28 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Like me, you may have a bad KVM.
Old 01-31-2017, 03:47 PM
Unhingd's Avatar
Diagnosis confirmed. They replaced and configured the KVM, and all is well. They also did the K410 (fuel canister hose) and K405 (service indicator) updates.
Is the service indicator function controlled by the ECU or some other module? I haven't lost any power, so I'm guessing it's not controlled by the engine ECU.
Old 01-31-2017, 04:02 PM
Received 4,458 Likes on 2,427 Posts
Service message is in the Instrument Cluster (IPC) so they would not have had any reason to touch the PCM.
Unhingd (01-31-2017)
Old 01-31-2017, 06:31 PM
Unhingd's Avatar
Perfect. Thanks for the info!
Old 02-02-2017, 06:49 PM
amr42's Avatar
I am curious if your problem is related to the problem I have lately. When I get out of the car and I hit lock on the fob the car does not respond. Then after a bunch of clicking and roughly 30sec-1min the car will finally decide to respond and lock, but I don't get a chirp when I double lock. Its super random and intermittent, but it drives me crazy when it happen.
Mine did this after a service visit. Seems dealer reset EVERY configurable setting - including AHB being set to driving on the 'LEFT'...! So check your settings after a dealer visit... My alarm chirp was turned off (must be default setting).
zmoothg (02-03-2017)
