Lateral play on lugnuts on 4 wheels - is this normal?
Not so. The caps on Jaguar wheels are not meant to be removed; the nuts are torqued to the specified amount with the caps in place.
Lucielle (10-21-2021)
That is absolutely correct. I just removed mine a little over a month ago. The chrome cap is pressed or crimped around the lug nut itself. There was plenty of wiggle between the two parts but without totally destroying it, no way to separate the two pieces. The solid steel chrome plated ones were a big improvement/
The following 2 users liked this post by SS4PK:
Lucielle (10-21-2021),
Spyderturbo007 (10-25-2021)
So I had the technician check and was told that it was the two piece design of the lugnuts.
We swapped them with solid lugnuts and there was no movement.
The trace amount of shavings was told to be normal, as part of taking them off and putting them on.
The vibration was attributed to a lost wheel weight from the front right wheel (there was some residual of adhesive).
So my next plan is to purchase some solid lugnuts (the local dealership said they only have the 2 piece kind, and they're $20 per nut) and swap them out.
What kind of solvent (water or alcohol) would you recommend to use to clean the studs and wheel interface?
Thanks!
Thanks!
Thanks!
Thanks!
If you must clean them for some reason, don’t use water, that will only encourage rust. Put some thin oil or WD-40 on a rag and wipe the studs off. Me….I’d do nothing.
Mahjik (10-19-2021)
Thanks!
Thanks!
I wouldnt clean the studs. Just wipe them off with a clean rag. As for the wheel interface, just a little soap and water and dry well.
#30
'07 XK: One of the two piece Jag lugnuts failed on mine. Amazingly stupid design. Never encountered that before on any car. So I replaced them all with solid chrome plated Gorilla lugnuts #73138 (Toyota spec, $65 set of 25). Cross tightened them with my torque wrench and no problems since. Happy car.
Cleaning grease: I've had real good luck with Simple Green.
#32
The seperation of the lug nut and the cap is caused by the vibrations of the impact gun. You can see scarring and indentations on solid nuts, as well. Only difference is their is nothing to seperate with a solid lug nut. It doesn't affect the function.
Use a soft bristle wire brush to clean off the dirt and contaminants on the lug bolts, then spray WD-40 or Silicone lubricant on a rag and wipe them, as previously mentioned.
#33
The separation of the lug nut and the cap is caused by the vibrations of the impact gun.
I bring our tires into the 'monkeys' at the tire store two at a time, off the car...and re-mount & tighten them myself (no air gun for THAT).
![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
The service writer probably say "Here comes the NUT again" when I walk in. LOL
#34
That must be why our lug nut covers are still secure. (Verified on a previous post)
#35
#36
Yes this is very well documented and we have hundreds of threads about the terrible design. Yes Jaguar has been using this design for over 20 years now. I have had 2 Jaguars and have replaced the crappy sheet metal covered lug nuts with solid versions as have many, many others. The factory ones will distort and eventually fail. Do yourself a favor and just eliminate this problem once and for all.
Get the solid lug nuts.
Carbuff2 (10-21-2021)
#39
#40
That's an interesting question and I blame Ford but don't know enough Jaguar history to be sure? The reason why I know about them is I had a 2003 Lincoln LS before I could afford a Jaguar and that car had them with all the same failures and problems we have on the Jaguar side.
My 2003 Lincoln LS, 2005 S Type R and my 2014 XJR had them. They are still installing them on current Jaguar models.
