Latest recall...do I have to have it done?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Brought my car in yesterday for the 2 year service and the service advisor told me there were 2 outstanding campaign's that needed to be performed, one was K309 which was completed with a PCM software update, the other is K410 which just appeared within the last few days according to the dealer and involves a canister and a hose that turns brittle...they didn't have the item in stock and it needed to be ordered, I got the call that it arrived today.
They told me it's a rather lengthy procedure that entails removing a lot (if not most) of the interior behind the drivers seat and that it would require me dropping the car off for a few days in which they would supply me with a loaner car.
I'm not especially keen on leaving my Polaris white car with Cirrus interior in the hands of others fearing the worst and am wondering if I HAVE to have this recall/bulletin/campaign done or can I opt no.
As it is, I lined the interior with blue painters tape to prevent scuffs and marks, as I do every time the car leaves my hands...one would call me **** and rightfully so...so obviously this doesn't sit that well with me.
So the question is: can I opt out?
buickfunnycar.com (11-11-2016)
If it involves dismantling the cabin I would not be keen at all - I can just imagine rattles etc after they put it back together again - once disassembled its never going to be as tight as the original factory build.
I would also want to know exactly what the fix is for - what the component is, how critical is it to the cars operation, likelihood of failure if you opt out etc
The following 2 users liked this post by ek993:
buickfunnycar.com (11-11-2016),
Burt Gummer (12-11-2016)
I just had K410 done. They definitely were into the trim behind the seats because a couple pieces of weatherstripping are now slightly askew, and there's a tool mark in the leather trim around the seatbelt housing. They will of course be replacing that....grrr.
They said the purpose of the recall is to replace a piece of tubing that is part of the emissions system. It can apparently rot and allow fumes into the cabin.
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
Just picked up my car from 2nd year service and warranty work to repair a coolant leak and buzzing in speaker(s). Work was finished Wednesday, today I asked the service rep. about K410 and he looked it up: my car MY2015V6S is flagged for it, but the work wasn't done because it wasn't flagged until after they finished with my car.
K410 relates to "canister & hose" behind the driver's seat, ozone degrading the hose.
The coolant leak was my first problem in 20 months of ownership ("rear crossover pipe leaking" and replaced). I had buzzing in speaker(s) called out at YR1 service, but never went back for the speaker(s) installation as they had to order the parts.
I will add: the fix - new speaker(s) installed this week (PS sub and door?) -- the Merridian Sound System has NEVER SOUNDED THIS GREAT! Then I turned off the radio and listed to the motor & exhaust sing, as usual....
Is K409 a recall, in which case all affected car owners must be notified, or a TSB (technical service bulletin), in which case they might mention it when we bring in the car for the next service?
Another question: Is there an identifier other than K409 which, when clicked, gets me to AutoAnything.com?
