Launch control
Old 01-19-2015, 09:39 PM
StealthPilot's Avatar
Default Launch control
Saw this picture on the Jag Instagram page. It says dynamic launch ready. Is this a 2016 feature? Launch control? I thought launch control wasn't possible with a ZF auto and that you needed a double clutch.
Old 01-19-2015, 09:54 PM
Adam B's Avatar
Launch control is available on the V6 cars, but not on the V8s. Not new for 2016.
Unhingd (01-21-2015)
Old 01-19-2015, 10:05 PM
shift's Avatar
Is it confirmed that it's not new for 2016? I wonder if with AWD they've added launch control for the V8...
Old 01-20-2015, 05:11 AM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Maybe launch control for the 6 speed?
Old 01-20-2015, 05:55 AM
OzRisk's Avatar
I believe it's fitted to the R coupe.
This screenshot from my owners manual...
Old 01-20-2015, 06:18 AM
Timbo's Avatar
Have a look at the foot note on your pic of the manual!!
"Not fitted to all derivatives"
The manual is the same manual for all F types.
Old 01-20-2015, 09:00 AM
jmfan's Avatar
I have launch control on my V6 S and it works great!
Old 01-20-2015, 09:05 AM
tiger4366's Avatar
My V8 S doesn't pretty darn good getting off the line without launch control anyway. Not sure I'd have much need for it.
Old 01-20-2015, 01:19 PM
OzRisk's Avatar
Yes, Timbo!! I did read that!! Thought I'd share it anyway!!
Old 01-20-2015, 06:57 PM
Timbo's Avatar
So why did you say "i believe its fitted to the R coupe then!"
Old 01-21-2015, 02:27 AM
OzRisk's Avatar
Cool
Because I "believed" it would be fitted to the R coupe, given it was in my owners manual, and the car is otherwise fully optioned.
If I was sure at the time, I would have said "I can confirm it is fitted". However, given it was 10:55pm, it was not my inclination to go starting the car to find out for sure, and wake up the children, the dogs or the neighbours in the process.
If that distinction is lost on you, let me help with an analogy that might be more relevant for you.
As defined in the dictionary, to "believe" is to "have confidence in the truth, the existence, or the reliability of something, although without absolute proof that one is right in doing so".
Noting your rather abrupt, exclamation ridden retort to my initial post, and observing you are located in London, one would "believe" you speak English as a primary language, and could understand the nuances of said language. However, this would be an assumption based on simple facts, and one would have no absolute proof that the assumption was correct without further evidence to evaluate.
However, you were kind enough to supply such further evidence through your subsequent post, which demonstrated that, whilst you have a predilection for pedantry, you lack some appreciation of the difference between a belief and a confirmed piece of knowledge. So the initial "belief" on my part that you had a full interpretive appreciation of the English language was flawed - my apologies. I stand corrected.
Oh, and as an aside, during more civilized daylight hours when I was less likely to draw the ire of my neighbors - canine and human, I went and tested the R Coupe for dynamic launch, and it is NOT a feature of that model. That is a FACT rather than a belief.
ndabunka (11-22-2017)
Old 01-21-2015, 07:59 AM
Timbo's Avatar
Blimey lol (laugh out loud)
Old 01-21-2015, 08:33 AM
It seems idiotic that they have the feature on the model that doesn't really need it, and the model which really needs it doesn't have it.
OzRisk (01-21-2015)
Old 01-21-2015, 09:31 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
I wouldn't say that the V6S "doesn't need it". It gets off the line noticeably quicker when you use it.
Old 01-21-2015, 09:58 AM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Uh, the V6 has no trouble burning rubber on launch. I would venture to guess that 90-plus percent of V8 buyers never even bothered to drive a V6 FType and are making assumptions about it absent any knowledge whatsover.
Old 01-21-2015, 10:58 AM
I'm not disputing that. It's a question of degree. My experience would say it is harder to launch a car with more hp than less hp.
I have owned cars with 197hp, 225hp, 333hp, 345hp, 400hp, 501hp, 550hp and 560hp. All RWD and all capable of burning rubber. More hp has always been harder to launch.
Old 01-21-2015, 11:10 AM
DJS's Avatar
DJS
DJS is offline
The launch control in the V6S is not what you'd want in the R. It locks up the torque converter so more torque makes it to the wheels at launch. I don't think the R needs more torque!
Old 01-21-2015, 11:14 AM
Unhingd's Avatar
All F-Types have traction control (DSC) to prevent wheel spin when it is turned on. Launch control (activated by holding the brake and gently prodding the throttle ) raises the stall speed on the torque converter to allow engine to remain within the peak torque rpm range (>2000rpm for example). This applies max torque through the drivetrain immediately upon takeoff. Maximum acceleration in a lesser powered car will occur with launch control activated and DSC left on (read: no wheel spin). The V8 has plenty of torque at any engine speed not to require fiddling with the torque converter stall speed. The V6 would benefit the most. This, of course, does not apply to the 6 speed since 1) no torque converter, and 2) the driver controls the "stall speed" with the clutch.
Old 01-21-2015, 12:03 PM
plmmd's Avatar
Have had launch control on a Carrera for 3 years- used it a few times the first few weeks (did the dealer say break-in? I didn't hear it ) then only when giving someone a ride- In the real world its an unused gimmick and unneeded
Old 01-21-2015, 12:45 PM
Mulmur's Avatar
I did drive both and the 6 does benefit from launch control and from the point of view of 'launch' the 8 does not really need it as it is a lot more powerful .. something that you can tell immediately from driving them both.
Lawrence.
Quick Reply: Launch control
