Leak Post Part 2
Leak Post Part 2
Hello, all!
I know I already posted once about this issue, but this time I’ve included a photo to show exactly what I’m talking about.
When I take my 2015 F-Type R through the car wash (touch less), I’ve noticed a leak/drip of water appear behind the headrests on both the driver & passenger side. Please see the photo below.
Has anyone experienced this before? If so, what might be the issue?
Thank you.
Thank you.
DonnyDB5 (03-12-2024)
That does appear to be more from the window than from the roof - the source of quite a few leaks over on the UK forum (where I linked you to in your other thread). Out of interest, have you checked the bottom of the boot/trunk to make sure that it is dry, just to rule out the leaky trunk liner seals?
IMO, the issue is that the pressure and spray direction in a touchless car wash exceed the real world parameters the seals were intended to resist. Perhaps the question you should be asking instead is "Where else is water being forced in, where it shouldn't get?" Plus, there's always that last layer of grime the touchless doesn't get off....
sov211 (03-13-2024)
