LED headlight.
LED headlight.
Good morning Guys.
I read the thread abat LED bulbs for the headlight.
But still not sure which is the best.
I hate the 4500k color of stock headlight which looks out of date.
I just want it more brighter and whiter.
Can anyone give me the link of LED bulb for the headlight without having me think abat this anymore?
Good morning Guys.
If you need plug amd play, the Car Rovers are better than stock.
Hi Racer
Thanks for the good info.
Is there much difference between both?
DZG or Car Rover?
If it's not, I prefer Car Rover.
If DZG is worth more, I will follow.
And you told me those products are linked in thread. I don't what you mean as I cound't find the link.
Could you please give me the links?
Thank you in advance.
DZG or Car Rover?
Hi Racer
DZG or Car Rover?
DZG or Car Rover?
IMO the DZGs are the way to go. They are brighter, the light is more even, they have brighter side lighting, better bright lights, and are slightly whiter. You have to solder 2 pigtails to use them, so 4 solder joints in total. It takes about 30 minutes per side.
We need D3S size bulbs.
Here are the DZGs that need conversion method 2
Here are pigtails for the DZGs
Here are the Car Rovers (plug and play)
Here are the coversion method 2 directions.
Wow.
Thx sooo much for the kindness.
I have no skills in touching wires so I better go for a Car Rover which seems out of stock for now.
Very sad.
If I get and install Car rover leds, I wonder if the color will fit the temperature of stock Z blade.( I don't know if it's correct, meaning the daylight turning on drive mode)
Very sad.
Wow.
Very sad.
Very sad.
Good luck!
https://www.jaguarforums.com/forum/f...1/#post2184752
Oops, I also fixed the link in post #4.
https://www.amazon.com/gp/product/B07WNTK4HN
Understood, With all the modding I do, though, I still don’t like making mods that aren’t reversible. Drilling holes and tapping into the wiring harness isn’t reversible. Don’t know why, since none of the mods on any of my cars have ever been reversed.
Building track or off-road dedicated vehicles was the exception, of course. Nothing much unmutilated left but the profile.
I might still consider tapping in the pigtails.
Good morning Guys.
As you don't do wiring, you might want to consider sticking with HID's, and upping the colour temperature....
Replace your stock OEM D3S's with D3S OSRAM Cool Blue Boost Xenarc 35W 6000K Xenon HID Bulbs.
They match the LED DRL's perfectly.
The problem with upping the temp is that visibility will decline unless the change is accompanied by a wattage increase.
I've had mine in a year now and noticed no difference in visibility.
Other than matching the colour temp of the Led running lights, the only other perceivable difference is that everyone else's headlight glare on the road is so yellow.
Agreed, but you miss my point. The OP wants brighter and whiter headlights. You can achieve that with the Osram CBB's, without necessitating LED fitment.
The increase in colour temp from 4.3K to 6K is a decrease in Lumens of a couple 100's maybe assuming the same wattage.
I could not notice this change in real life at all.
This helps explain:
This helps explain:
