Life Is Short, Drive Your Damn F-Type!
Damn... I'm a whole 10k behind you! (But I can see yours isn't a 2016. I'll work on catching you. That May Lobster Run will add a few thousand quite quickly!)
It's good to know people drive these cars and they aren't all garage queens!
#28
#30
Mine has been in the garage for a month now, but finally the roads were cleared and dry, and it seemed a good time to get her out for a winter run. Temperature was 24 F here at 8,000 in Colorado. Mine is a Base with Continental SC2 tires. My driveway is still snowpacked, but I figured it'd be OK. Mistake. As I crept down my driveway, 250 ft long with a 10 degree slope, there was no traction at all. It was like I was on ice skates. As I crept down, the car was sliding down and sideways towards the ditch. Oh my! I managed to get it to the road, but realized there was no way I could drive it back up. Still we had a nice drive out to lunch, a shopping stop, and groceries. Now, how do I get her home? I called for a flat-bed tow truck. The guy was good and very careful and we got her home without damage. I'll get it out again in winter, but not unless my driveway is melted down to the gravel. And, after driving it again, we realized how much we missed it. It was a blast. Come on sun.
#32
#33
The go-pedal is still analog, not binary.Throttle input modulation is every bit as effective as the snow mode nanny. Full DSC, however, is quite useful in slippery conditions, and love the TVB.
#35
Hey f-typers, I have been contemplating moving from my XF to an f-type. I think my preference is for a 2016 due to awd as I am thinking to drive it year round as I do my XF, so i hope tagging on to this thread is ok. I wanted to know what offsets are required for f-type, hoping I could use my winter setup with Nokia Hakka R's on the f-type. My oem 20''s are 49 front, 66 rear, if I remember correctly, but my Savinis are 35 and 49 if I recall. Savini''s are 20''s too. Nokia are 8 inch wide at all corners.
#36
Number of Bolts: 5
Rim Material:Alloy
Bolt Pattern:5x108
Rim Width: 9 FRONT / 10.5 REAR
Hub Bore:63.4
Rim Diameter:20
Rim Structure:One Piece
Offset:55 FRONT / 38 REAR
To advise regarding your winter setup, we will need more specifics:
Rim width
Actual Tire size (not the measurement)
You'll need to confirm whether the bolt pattern and hub bore are compatible.
jaguny (02-18-2016)
#37
Mine is still tucked away in the garage with summer tires on, and has been so for a while.
Before new year the roads were wet and full of dirt and salt. Now it has been between -10 and -15 celsius since new year, and we have gotten a bit too much snow. The same cold weather is expected to last at least through January, so it will be some time before I get to drive it.
Looking very much forward to spring though
#38
Um, snow tires are for snow.
#39
Looking very much forward to spring though![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
#40
