Life Is Short, Drive Your Damn F-Type!
#41
Here are the specs on the 20" OEM F-Type wheels.
Number of Bolts: 5
Rim Material:Alloy
Bolt Pattern:5x108
Rim Width: 9 FRONT / 10.5 REAR
Hub Bore:63.4
Rim Diameter:20
Rim Structure:One Piece
Offset:55 FRONT / 38 REAR
To advise regarding your winter setup, we will need more specifics:
Rim width
Actual Tire size (not the measurement)
You'll need to confirm whether the bolt pattern and hub bore are compatible.
Number of Bolts: 5
Rim Material:Alloy
Bolt Pattern:5x108
Hub Bore:63.4
Rim Diameter:20
Rim width
The bolt patterns and hub bore are the same, as with most modern jags. Both sets of rims are 8.5 front 9.5 rear. Seems like I would need a set of new wheels dedicated for winter.
#42
jmarkitell
12-19-2015 01:18 PM
