Lift gate not automatic closing ??
winstonsalemncxk (05-28-2022)
Received 3,209 Likes
Many members here, after experiencing battery/electrical problems (many and various), have "rebooted" the system by disconnecting then reconnecting the battery, and it works to solve the problem most times.
The easiest way to disconnect the battery is to disconnect the earth/ground lead which runs from the negative terminal of the battery from where it is bolted down at the other end of the cable to the floor of the trunk/boot. It is a think black cable, easy to spot, and where it bolts down is also easy to trace and spot. From memory it is held on by a 13 mm nut, remove that nut, lift the cable off the bolt and keep it away from touching any metal part for some 30 seconds or so, then reconnect and bolt back down again.
This might just reset/fix the hatch close module/button/switch/motor/whatever but then again it might not but worth a try and it only takes a minute or two.
You will lose the Trip 1 and Trip 2 readings (they will reset to zero) and the one-touch window up/down but no biggie losing the Trip readings and it's a simple procedure to reset the window one-touch. Nothing else will be lost or need resetting other than maybe the time/clock which is also easy to reset.
Forgot to add, as davidmaria1 says disconnecting the battery will always disable the hatch power close the first time, you have to manually pull it down the first time after a disconnect then it should work as normal after that.
The following 2 users liked this post by OzXFR:
theEIger (05-29-2022),
The following 2 users liked this post by Borbor:
scm (05-28-2022),
As someone else mentioned, might need to check the battery. On our Evoque the car started and everything seemed to work fine, but lift-gate would open but not close with engine off.... Ended up being a marginal battery.... Have not had the problem on our F Type... This might be at least worth checking... You might also try opening and closing with the engine running to see if that makes a difference... By the way, the Evoque works differently and doesn't close with fob or dash button by design, but it would not close, with engine off, with the button on the lift gate either.... :-)
Completely unscientific, but is the car running when you try it? The running voltage will (?) be higher then. Make sure both keys are linked to the car, holding the fob near the left lower dash, the sequence is here on the site somewhere.
slmskrs
12-09-2014 05:58 PM
