Lightweight battery?
FYI, Antigravity has a H8/Group 49 size now, so an exact swap for our cars. $950 is still too dear for me. I can only imagine the price will continue to go down... I hope...
https://antigravitybatteries.com/pro...tive/ag-h8-rs/
Unless you are a fan of the start/stop feature, you just ditch the 2nd battery and save more weight. The RS30 I put in was roughly the same weight as the small 2nd battery (15 lbs), so by switching out both I removed about 65 lbs. Although, that was when they cost low $600's, someone says they are $950 now???
The original battery being referred to is the RS30: that was ~$600 but is now $700, is of lower capacity and lighter, and needs custom mounting in our cars. 30 Ah/11.5 lbs
The link I posted above is a new product, a straight swap* in a standard automotive size that fits the F-Type, and is $950. It's 60 Ah / 19 lbs
*At least it is for single battery F-Types. I don't know about the 2-battery models.
Interestingly enough, the search by vehicle facility on this website has only a single '2014-2017' option when selecting an FType. I'm not sure I trust this without contacting them first unless someone has experience with trying this on an older FType.
Maybe Ill measure my current battery and terminal locations
Paul champagne (10-31-2019)
#31
#32
I believe this is the OEM Varta battery...
https://www.dropbox.com/s/5tvrtsxpyl...5D852.pdf?dl=0
I see prices of around $600, though I haven’t looked much. Wonder what the dealer would charge, though I don’t know if they’d bother with the OEM battery.
Yes, a generic H8 AGM would be less.
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/980x2000/screenshot_20191102_220845_chrome_c27af9fcc5d8d947907c4adc002018b95f382420.jpg)
£179 is US $230 at today's exchange rate
#33
#34
I've installed the Liteblox LB26XX two years ago, saving approx. 58 pounds (including the weight reduction for the OEM battery tray/holder being repaced with a carbon plate holding the battery), in my 206MY V6S. Has worked like a gem, never had a need to trickle charge, not even during the 5 months winter break where the car is in storage. Start-stop luckily disappeared after installing the Liteblox battery. Installation was very straightforward. Now with the gym closed due to lockdown the old and heavy battery came in handy for use as a kettlebell :-)
jahummer (06-08-2020)
#35
The ATX30RS is the successor battery to the RS-30 that I am currently using. Has never failed me even in sub-zero temps without using a battery tender. As mentioned, the ECO stop/start feature won’t work when these lithium batteries are installed. (No real loss).
#36
#37
The successor to their original RS-30 (1200CA/30Ah) that some folks here have, is the ATX30-HD and is $560. It's 970CA/48Ah.
Both are sold as motorcycle batteries, the HD also as automotive, and both require custom mounting to our cars.
Their direct replacement automotive battery is still $950 and has 1800 CA/60Ah. I think our OEM batteries are around 950CA.
JgaXkr (06-09-2020)
#38
#39
jahummer (06-10-2020)
#40
