Likely I'm no Audiophile, but...
Finally took the time to focus a bit on the stereo/radio in this F-type. The way people have been talking on here I was expecting this thing to be absolutely horrible. I don't find it to be bad at all myself. That's at stock settings. I didn't mess with it at all and I'm pretty happy with it. I was just listening to radio too, so I suspect it I used a better source of some kind I would really be good with it etc...
It's like anything else I guess, we all have different ideas of what sounds good/bad...I sprung for the "Surround" version to give it the best opportunity to be sounding as good as possible. Either way, I'm good. Perhaps my bar is not very high, not sure...
The following 2 users liked this post by DMeister:
Thunderjet Racing (06-01-2024),
VroomForTwo (06-03-2024)
The following 2 users liked this post by alchemystic:
Most complaints surround the buzzy bass, mainly due to the location and lack of effort to seal the “enclosure” of the rear subs.
The doors aren’t well prepped for quality audio either, but not any worse than other cars.
There were bugs in the amp program causing tweeter problem, and other trim buzzing related issue.
They were somewhat addressed in newer models.
Oh and another point was the audio sounds bad for the price of the car.
I'm fortunate to have the 770 watt Surround system in my 2023 P450
The box of DYNAMAT arrived yesterday afternoon
I had a 2013 Mustang, 420 HP V-8 with wonderfully sweet sounding GT 500 mufflers.
Did the weel wells, floors, doors, driveshaft tunnel and trunk.
Killed road noise and allowed the exhaust to stand out
the difference was EXTREME
Hoping for the same - will report results back here
BEST !
RWS
BEST !
RWS
BEST !
RWS
BEST !
RWS
Exactly, it’s not better or worse than most other cars, and that’s a fault for a 100k + gt car with a labeled premium system.
The following 2 users liked this post by Ray Ray:
SouthSider (06-01-2024),
There is definitely something wrong with the F-Type's audio system, at least in my '16 R with the Meridian Surround there was.
My son's '17 XE Meridian Surround system sounds so much better and the drivers aren't anywhere near the quality the F-Type had.
The F-Type's "tune" (time alignment, EQ, crossover settings and individual driver levels) was way off, I couldn't get a decent sound stage out of the factory system and the sub's were one note wonders.
There was absolutely no punch or dynamic range from the amp.
The enclosure for the subwoofer drivers was beyond horrible, nothing but resonance from the trim pieces.
It's a bit like saying the factory supplied Pirelli's are OK. Sure, they round, they black and they hold air but really...
There are better products then Dynamat and better applications than sticking it to every surface.
https://www.secondskinaudio.com/soun...soundproofing/
There were issues apparently at one point with the wrong software being installed that can be corrected by a dealer. My experience, be sure to select the Meridian Surround option when tweaking the settings. I find my 2017 S sounds. fine. But, I listen to the music not the system, and also don't like play the kind of music that requires heavy bass.
Not disagreeing, but for my tastes in music the 380 Meridian is much better than the B & W XKR. I thought the latter was pretty tinny and I'm told it was great for jazz which I dont listen to, and it did play very nicelyan acoustic based song I was listening to.
The 380 Meridian sounds pretty good to quite good for heavier beat music if it is turned up, it sounds awful to me on low. It can handle quite heavy bass without distorting too much, and since we are talking about breathing, if you want to test it whack "Breathe" by Zabo on in the car and you will see how much it can take.
Just added Dynamat to the doors and trunk.
see thread:
Road Noise - Jaguar Forums - Jaguar Enthusiasts Forum
Outstanding improvement - my 770 Meridian now sounds 100% better.
Too bad the bean counters at the factory wouldn't allow for this.
Likely the same fellows who made the decision to go all electric.
BEST !
RWS
see thread:
BEST !
RWS
My experience is that some recordings sound fantastic and some sound like crap. Also a lot of the mid-bass ‘flapiness’ (around 80hz) distortion at moderate volumes oddly goes away at higher volumes. There is plenty of speaker hardware (albeit with compromised enclosures) and amplifier power, but clearly there are defects in the EQ and signal processing.
