limited slip differential question
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
What is the limited slip differential?
and
What is the difference between the mechanical limited slip differential on the V6s and the electronic limited slip differential on the R coupe?
and
if someone wants a V6 not S, Should he consider going for the S just because of the limited slip differential?
and
and
Having owned very high performance cars with limited slip differentials, I have the base V6, and I don't miss it, but mine is exclusively for street use. It would make a difference for track use.
The base suspension and drive train are very capable, and there's no horsepower and torque difference between the V6 and V6s engine until 5K RPM.
I would have to respectfully differ with Foosh.
With the V6 there is a big difference in exhaust tone and loudness with the active exhaust on vs off.
The stock exhaust may be loud enough for some, but the active exhaust is heart thumping,head snapping, fist pumpingly louder.
It's definitely overkill and downright immature for some, but it's worth listening to the difference because for others it is sh*t-eating grin awesome!
Oh yes, there's definitely an obvious difference, but I guess I've "outgrown" things like that.
C6 Z06's also had "active exhaust" std, but the valves only opened at 3/4 WOT, and didn't come with a switch. You could buy a switch for less than $50, which plugged in place of the fuse controlling that valve and mounted on the console to manually open and close them at any time, which I and many other owners did. After the initial infatuation for a few months, I found myself leaving it off 98% of the time. However, the V6 without, seems louder than that car with exhaust valves open, if my memory serves me well.
I honestly don't know how JLR gets away with the noise regulations in many countries. I find myself having to be very careful to modulate the noise even without active exhaust as it still draws a considerable amount of attention.
Curious to know if you have any idea of the differences, sound wise, between the 'standard' exhaust system and the active exhaust in its open vs closed positions. For example - is the standard the same as the active with the valve(s) closed, or somewhere in between the active closed/open?
mshedden (11-17-2014)
My V6 seems louder that the V6S I test drove when the valves were shut.
I can see good marketing reasons for this to be so, but isn't neccesarily the case.
The adaptive dynamics will make a difference to the ride, and will allow you to vary other parameters independently. The differences may also be marketing-led however.
mshedden (11-18-2014)
I have the base V6 and I think that the lack of an active exhaust simply means that the exhaust is always in the "open" position. I drive in dynamic mode on/sport shift on 98% of the time and the sound is very aggressive. I had the resonator deleted, which adds to the aggressive sound as well.
xjrjag
09-27-2015 01:53 AM
