Locked out
Please read your owner's manual. It is all there. But for immediate satisfaction: the positive connection point is under the red cover. Just to the left of that cover (meaning closer to the windshield) is a threaded post. That is the negative connection....but the best place and permanent place to connect the CTEK unit (if that is what is in question) is in the trunk (and there are specific instructions in several threads here). If you rely on the connection points under the hood/bonnet, you will end up not using the charging unit because it is not convenient. But if you make permanent connections in the trunk, the process of connection takes a matter of a few seconds.
Jagged Wire (12-13-2018)
Since I did that install I have figured out how to tuck the end of the pigtail up under the edge of the bonnet/hood, between the metal and the plastic lining, such that I simply have to pull the lead out from the outside of the car then tuck it back away when I am finished with the charger. No fuss, no muss, works perfectly every time!
