Longer Wheel Studs -- What are the options?
Hi all,
As the thread states, are there options out there for longer wheel studs? Either something aftermarket or OEM?
The only info I can find about our studs is below:
M12-1.50 Serrated Wheel Stud - 13.25mm Knurl, 51.63mm Length
Thanks in advance.
Thanks in advance.
Bumping this. I did an extensive search and could not find anything exact.
According to what I've been able to find online the OE studs are: https://www.dormanproducts.com/p-243...20Lug%2520Stud
And the closest I've been able to find is: https://arp-bolts.com/kits/arpkit-de...hp?RecordID=78
Swapping studs is certainly possible, just a time consuming, and you may need a shop to slightly bore out the hub hole just a tad.
Jagman 999
04-06-2014 12:16 PM
adam12hicks
02-10-2009 04:17 PM
