Looking for plugs that connect rear wiring
They look like off-the shelf parts. I suggest you ask on an electronics forum like eevblog
Folks there can also advise on an appropriate crimp tool.
https://www.eevblog.com/forum/index.php
Whilst some connectors are classed as 'unserviceable', most are and you can buy replacement connector housings and pre-terminated wires to make repairs. The middle green and black connector are definitely available to buy from JLR parts as they are connectors used for 20+ years now. I'm not sure about the 8 way green one but normally unless they are specialist connectors like high speed data or AV ones then they are available.
I'm not intimately familiar with the F-Type wiring so I don't recognise that harness. If you could reply with the fitted location (left hand side of the trunk?), and/or the long XXXX-XXXXXX-XX number printed on the label I can look it up and see if the parts are available. If you can't get a harness number, then do you at least know what one of those plugs connects, or one of the circuits that runs through it as I can look up those to locate them?
Leonard_85
28
08-30-2012 07:09 PM
