Loose reading light
Loose reading light
Hi, I recently purchased a used 2017 Jaguar F-Type coupe and just now noticed that the component which has the reading light is loose on the driver side. I tried to push it upwards but it doesn't move. Is there a quick fix that I can do, or I have to take this to the dealer? Thanks!
So see why it won't push up and snap into place you'd need to pop it completely loose and see what's blocking it. It snaps into place, and is easiest to pop loose with a trim tool. I've had mine out a few times, since that's where my radar detector is wired in. There might be a plug that's not tucked in properly interfering with proper placement.
