Loss in power between 2k-3k
i am having this weird issue with my car (v8r). I haven't tried to see if this occurs with the oem tune, but it happening now and I'm running the VAP tune, so the tune may not be related. However in 1st gear, and 3-8 the car pulls nice and linearly. However in 2nd gear after upshifting from 1st, the car will start to pull, then power is stripped around ~2.8k and the rpms fall to ~2.2k and then it finally starts to pull again. Does this happen to any of you with V8s? It troubles me and throws me off. It's very reproducible. Need to try to gopro the phenomenon.
OOOh! Good point!!! I had the same phenomenon when I did the final power bump with the lower pulley. The power would shut down for a second or two after a vigorous first to second shift. I forgot about that. Put the car in TrackDSC. Issue goes away (as do the tires).
Yes this is exactly what happens. I'll reach out to Chris. I'll also see what happens when I'm in trackdsc mode.
Yup, its a pedal mapping issue. Not everyone gets this issue it would seem, but the OEM pedal cal gets a bit weird when you've added power. Took us months to figure it out and it was completely by accident.
I am going to defer on this one, but suggest giving the TracDSC (or no DSC) a try. Throttle mapping is one of the biggest challenges with tuning these engines. I have experienced the opposite of flat spotted throttle mapping. I have at least one throttle position at which there is a sudden power increase as you transition through that position. VAP was able to eliminate it on a milder tune (450hp) but it is still present on the hottest tune (456hp).
