low battery and indie inspection
jaguny (05-09-2018)
jaguny (05-09-2018)
It is not only possible, it is what happened. If they did not shut down the program for the OBD II reader before unplugging, that is what happens. Disconnect your battery, wait for a minute, reconnect. Solved. There is a thread on exactly this issue.
jaguny (05-09-2018)
Received 3,226 Likes
Easiest way is to disconnect the earth lead from where it bolts to the floor of the trunk - a single 14 mm (maybe 13, maybe 15, I forget now!) nut.
You don't need to disconnect both positive and negative/earth, just the earth does the trick and it's much easier than the negative or positive battery terminal lead.
The only settings I have ever lost are the one touch window up/down, easy enough to reset (although for some weird reason in my case the car has to be moving!), and you will lose your Trip A and Trip B figures.
scarbro2011
07-24-2016 05:28 PM
