Lower SC Pulley
Old 12-29-2015, 06:06 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Default Lower SC Pulley
It appears that there are now, or soon to be a number of upper/lower pulley change combinations to allow for some degree of tuning flexibility. Having one or two lower pulley options available is particularly important to the V6 cars since the upper pulley can only be reduced by 2.5% without binding on the SC housing. Having 2 lower pulley options for the V6 offers 2 additional states of tune. Additionally, having 1 aftermarket upper pulley available offers 5 additional states of tune for the V8.
Old 01-06-2016, 07:37 AM
mshedden's Avatar
From my limited experience, aftermarket crank pulleys often do not have the harmonic balancer component that factory crank pulleys have to dampen vibration. Without the harmonic balancer there is some risk of engine wear / damage, which some are willing to live with.
Is there a harmonic balancer / damper incorporated into this design, or is it a simple machined 'wheel' (for want of a better description)?
Old 01-06-2016, 07:54 AM
Unhingd's Avatar
On the F-Type, the lower SC pulley bolts to the face of the harmonic balancer, so you need nothing more than a machined hub-centric (for proper centering) pulley.
mshedden (01-06-2016)
Old 01-06-2016, 03:19 PM
mshedden's Avatar
Ok, if that's how vmax implements it, then fine - parts refs seem to indicate factory pulley and balancer are a single part(?) Perhaps vmax will confirm.
Old 01-06-2016, 05:31 PM
Unhingd's Avatar
VMax isn't the provider of that solution. Eurotoys is. When that kit arrives, I will inspect and photograph. If the original harmonic balancer does not remain intact and used , I will not install the kit. I will let you know in about 4 weeks.
Old 01-06-2016, 06:57 PM
Stohlen's Avatar
Is it actually two separate pieces (with the balance being on the serp. belt pulley) or are you just speculating based on photos? I see the bolts as well, but never looked that closely into it. If this is indeed the case, there's absolutely no reason why we need $1000+ solution for this when a simple billet machined pulley for a third of the cost would do just fine.
Old 01-06-2016, 08:34 PM
Unhingd's Avatar
This is what I am being told. I will confirm before installing. As with all aspects of the tuning process, one gets different answers based on whom you ask. Caveat emptor. It is up to us, the consumers, to confirm the facts. I will keep you posted with my findings.
LobsterClaws (01-07-2016)
Old 01-07-2016, 09:51 PM
Stohlen's Avatar
Thanks, keep us posted with lots of pictures and install information!
Old 01-08-2016, 06:01 PM
Ubad2's Avatar
Banned
Default You are correct Sir !
I believe STEVE DINAN wrote a detailed article on this topic which can be found/read on the DINAN web site. Referred to as, HARMONIC DISTORTION. bad news for the motor .
Old 01-08-2016, 06:12 PM
Ubad2's Avatar
Banned
Post Here is the write up by DINAN, re: pully installation and its problems
THE DANGERS OF POWER PULLEYS AND UNDERSTANDING THE HARMONIC DAMPER
by: Steve Dinan
I have been threatening for a long time to write a series of technical articles to educate consumers and to dispel misconceptions that exist about automotive after-market technology. Motivated by problems with customer’s cars resulting from the installation of power pulleys, I wish to explain the potential dangers of these products and address the damage they cause to engines. The theory behind the power pulley is that a reduction in the speed of the accessory drive will minimize the parasitic losses that rob power from the engine. Parasitic power losses are a result of the energy that the engine uses to turn accessory components such as the alternator and water pump, instead of producing power for acceleration. In an attempt to minimize this energy loss, many companies claim to produce additional power by removing the harmonic damper and replacing it with a lightweight assembly. While a small power gain can be realized, there are a significant number of potential problems associated with this modification, some that are small and one which is particularly large and damaging! The popular method for making power pulleys on E36 engines is by removing the harmonic damper and replacing it with a lightweight alloy assembly. This is a very dangerous product because this damper is essential to the longevity of an engine. The substitution of this part often results in severe engine damage. It is also important to understand that while the engine in a BMW is designed by a team of qualified engineers, these power pulleys are created and installed by people who do not understand some very important principles of physics. I would first like to give a brief explanation of these principles which are critical to the proper operation of an engine. 1) Elastic Deformation Though it is common belief that large steel parts such as crankshafts are rigid and inflexible, this is not true. When a force acts on a crank it bends, flexes and twists just as a rubber band would. While this movement is often very small, it can have a significant impact on how an engine functions. 2) Natural Frequency All objects have a natural frequency that they resonate (vibrate) at when struck with a hammer. An everyday example of this is a tuning fork. The sound that a particular fork makes is directly related to the frequency that it is vibrating at. This is its “natural frequency,” that is dictated by the size, shape and material of the instrument. Just like a tuning fork, a crankshaft has a natural frequency that it vibrates at when struck. An important aspect of this principle is that when an object is exposed to a heavily amplified order of its own natural frequency, it will begin to resonate with increasing vigor until it vibrates itself to pieces (fatigue failure). 3) Fatigue Failure Fatigue failure is when a material, metal in this case, breaks from repeated twisting or bending. A paper clip makes a great example. Take a paper clip and flex it back and forth 90° or so. After about 10 oscillations the paper clip will break of fatigue failure. The explanation of the destructive nature of power pulleys begins with the two basic balance and vibration modes in an internal combustion engine. It is of great importance that these modes are understood as being separate and distinct. 1) The vibration of the engine and its rigid components caused by the imbalance of the rotating and reciprocating parts. This is why we have counterweights on the crankshaft to offset the mass of the piston and rod as well as the reason for balancing the components in the engine. 2) The vibration of the engine components due to their individual elastic deformations. These deformations are a result of the periodic combustion impulses that create torsional forces on the crankshaft and camshaft. These torques excite the shafts into sequential orders of vibration, and lateral oscillation. Engine vibration of this sort is counteracted by the harmonic damper and is the primary subject of this paper. Torsional Vibration (Natural Frequency) Every time a cylinder fires, the force twists the crankshaft. When the cylinder stops firing the force ceases to act and the crankshaft starts to return to the untwisted position. However, the crankshaft will overshoot and begin to twist in the opposite direction, and then back again. Though this back-and-forth twisting motion decays over a number of repetitions due to internal friction, the frequency of vibration remains unique to the particular crankshaft. This motion is complicated in the case of a crankshaft because the amplitude of the vibration varies along the shaft. The crankshaft will experience torsional vibrations of the greatest amplitude at the point furthest from the flywheel or load.
Simplified Flywheel and Crankshaft Assembly
Harmonic (sine wave) Torque Curves
Each time a cylinder fires, force is translated through the piston and the connecting rod to the crankshaft pin. This force is then applied tangentially to, and causes the rotation of the crankshaft.
The sequence of forces that the crankshaft is subjected to is commonly organized into variable tangential torque curves that in turn can be resolved into either a constant mean torque curve or an infinite number of sine wave torque curves. These curves, known as harmonics, follow orders that depend on the number of complete vibrations (cylinder pulses) per revolution. Accordingly, the tangential crankshaft torque is comprised of many harmonics of varying amplitudes and frequencies. This is where the name “harmonic damper” originates.
Critical RPM’s
When the crankshaft is revolving at an RPM such that the torque frequency, or one of the harmonic sine wave frequencies coincides with the natural frequency of the shaft, resonance occurs. Thus, the crankshaft RPM at which this resonance occurs is known a critical speed. A modern automobile engine will commonly pass through multiple critical speeds over the range of its possible RPM’s. These speeds are categorized into either major or minor critical RPM’s.
Major and Minor Critical RPM’s
Major and minor critical RPM’s are different due to the fact that some harmonics assist one another in producing large vibrations, whereas other harmonics cancel each other out. Hence, the important critical RPM’s have harmonics that build on one another to amplify the torsional motion of the crankshaft. These critical RPM’s are know as the “major criticals”. Conversely, the “minor criticals” exist at RPM’s that tend to cancel and damp the oscillations of the crankshaft.
If the RPM remains at or near one of the major criticals for any length of time, fatigue failure of the crankshaft is probable. Major critical RPM’s are dangerous, and either must be avoided or properly damped. Additionally, smaller but still serious problems can result from an undamped crankshaft. The oscillation of the crankshaft at a major critical speed will commonly sheer the front crank pulley and the flywheel from the crankshaft. I have witnessed front pulley hub keys being sheered, flywheels coming loose, and clutch covers coming apart. These failures have often required crankshaft and/or gearbox replacement.
Harmonic Dampers
Crankshaft failure can be prevented by mounting some form of vibration damper at the front end of the crankshaft that is capable of absorbing and dissipating the majority of the vibratory energy. Once absorbed by the damper the energy is released in the form of heat, making adequate cooling a necessity. This heat dissipation was visibly essential in Tom Milner’s PTG racing M3 which channeled air from the brake ducts to the harmonic damper, in order to keep the damper at optimal operating temperatures. While there are various types of torsional vibration dampers, BMW engines are primarily designed with “tuned rubber” dampers.
It is also important to note that while the large springs of a dual mass flywheel absorb some of the torsional impulses conveyed to the crankshaft, they are not harmonic dampers, and are only responsible for a small reduction in vibration.
Cut-Out View of a Tuned Rubber Harmonic Damper
In addition to the crankshaft issue, other problems can result from slowing down the accessories below their designed speeds, particularly at idle. Slowing the alternator down can result in reduced charging of the battery, dimming of the lights, and computer malfunctions. Slowing of the water pump and fan can result in warm running, while slowing of the power steering can cause stiff steering at idle and groaning noises. It is possible to implement design corrections and avoid these scenarios, but this would require additional components and/or software.
Our motto at Dinan® is “Performance without sacrifice”. We feel our customers expect ultra high performance along with the legendary comfort and reliability of a standard BMW.
While it is common that a Dinan® BMW is the fastest BMW you can buy, performance is not our only goal. Dinan isn’t just trying to make the fastest car. Instead a host of considerations go into the development of our products. Dinan puts much more effort into these other areas than does our competition.
These considerations are Performance, Reliability (Warranty), Driveability, Emissions, Value, Fit and Finish. We feel that the power pulley is a bad way to get extra power from and engine and the potential for serious engine damage is too great.
This is a simplified explanation meant to be comprehensible by those who are not automotive engineers. In trying to simplify an extremely complex topic some precision was sacrificed although we believe this explanation to be as accurate as possible. We encourage our customers to educate themselves and understand the automotive after-market because we believe that our products are the best researched, engineered, and fabricated products available.
For those interested in a more in depth and technical explanation of this topic, the reference book is Advanced Engine Technology, written by Heinz Heisler MSc,BSc,FIMI,MIRTE,MCIT. Heinz Heisler is the Head of Transportation Studies at The College of North West London. His book is distributed in this country by the SAE (Society of Automotive Engineers).
The following 2 users liked this post by Ubad2:
Mbourne (01-08-2016), Unhingd (01-08-2016)
Old 01-08-2016, 07:19 PM
Unhingd's Avatar
Certainly reaffirms my notion that I won't consider any lower pulley swap unless it retains the harmonic balancer.
Old 01-09-2016, 08:27 PM
mshedden's Avatar
Weeeeelł, my original post was in the vmax crank pulley thread (before it was moved here), and was in reference to that subject. The question remains unanswered for anyone contemplating replacing their crank pulley with any aftermarket one. The bottom line is that without a harmonic balancer, engine damage is a real possibility, and any purchaser of such a product should be aware of this, particularly on a non racing type forum where the members may not be aware of the issues.
Old 01-09-2016, 08:41 PM
Unhingd's Avatar
+1.!!!!
Old 01-09-2016, 08:52 PM
Ubad2's Avatar
Banned
Default No disrespect intended from.me .....
But I think you guys are experimenting with your very expensive car's and taking a big risk for potential problem down the road. If I were to mod out the engine, the tuning company would have to be as experienced as DINAN. They do extensive R & D to prove the modification part will not damage the vehicle. Unfortunately, no such outfit exists for the Jaguar F Type car. So I will not alter the engine. Too big of a risk.
Old 01-09-2016, 09:13 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Originally Posted by Ubad2
But I think you guys are experimenting with your very expensive car's and taking a big risk for potential problem down the road . . . So I will not alter the engine. Too big of a risk.[/B]
That would also include sticking with the appropriate spec oil.
The following 2 users liked this post by Foosh:
JgaXkr (01-10-2016), TXJagR (01-09-2016)
Old 01-10-2016, 12:23 AM
Stohlen's Avatar
Don't think Dinan superior to all others just because they work within the factory warranty. That is built into the cost. There are those among us who are educated enough to take these risks, knowing the fundamentals of the part design and being able to calculate the added stress to understand the likelihood of a failure. That being said... my rule of thumb is: don't mess with engine unless you're willing to replace it.
Ubad2 (01-10-2016)
Old 01-10-2016, 06:25 AM
Unhingd's Avatar
+1.
Old 01-10-2016, 07:31 PM
cbroth1's Avatar
Yes, you are taking a system engineered for performance AND "longevity" and knowingly pushing it outside the envelope in order to gain performance. Even if done safely, no amount of math can prevent the added wear and increased risk of failure. All you can do is address potential weaknesses in the modified system assuming they are known and part are available.
+1 to the quote. You can't expect the manufacturer to back your "race car", unless you drive for them.
Old 01-10-2016, 08:45 PM
Eurotoys's Avatar
Former Sponsor
The rear portion of the factory 5.0/3.0 crank pulley is the harmonic dampner, the front part (that drives the s/c) is not a engine dampner, but has a rubber ring inside of it. That front rubber is to help with n/v/h. Jaguar has had this since 2002 on the 4.0L (last 2 years of the 4.0 used this. When we modify a crank pulley (4.0/4.2/5.0 & 3.0) that outer rubber is eliminated when we use a solid/billet pulley.
So why would Jaguar use that outer rubber? We believe it is to help reduce noise from the s/c in non-boost situations (mostly idle). Even though the idle speed is specified by the ECU, the engine really speeds up/slows down rapidly causing the s/c to rattle. They also use a spring loaded coupler inside of the s/c to reduce noise.
Our solid lower s/c pulleys are precision made and do not affect the engines balance. Also, due to the nature of the pulley being much larger you have more belt wrap, which itself helps dampen and reduce any n/v/h issues.
Old 01-10-2016, 09:25 PM
Stohlen's Avatar
Now I will say this is typically how things work when modifying cars (specifically on the power front), but it isn't always the case. There is more that OEMs are concerned with than just performance vs. longevity. They also have to deal with emissions, fuel economy, cost, availability of materials, etc. and that all factors into the design of each individual part. Historically there are some engines out there that are so over built from the factory that you can easily double their horsepower output without opening the engine and it will still outlast the rest of the car. (i.e. 2JZ supra motor or N54 BMW twin turbo) These are also some of the most popular cars to modify for obvious reasons.
Quick Reply: Lower SC Pulley
