Lowered my R...
Old 01-26-2016, 05:51 PM
Timbo's Avatar
Default Lowered my R...
Finally bit the bullet and lowered my "R", think i might be the first in the UK
but happy to be told otherwise.
How high lol
FD9NY (01-26-2016)
Old 01-26-2016, 06:56 PM
shift's Avatar
Looks good, which springs did you go with?
Old 01-26-2016, 07:46 PM
Stohlen's Avatar
Wheels need to be spaced out now.
ImNotFamousAnymore (01-27-2016)
Old 01-26-2016, 08:31 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Ah yes, the thrill and agony of car customization. Once you start, it almost never stops.
I do agree that the OEM offsets look pretty good at OEM height, but once lowered the wheels do need to be pushed out.
Old 01-26-2016, 09:36 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
+1. 15mm all corners seems to be just right.
Old 01-26-2016, 09:51 PM
Dremorg's Avatar
Nice drop Timbo. Looking good.
Old 01-27-2016, 03:18 AM
Timbo's Avatar
H&R springs, they dropped it about 1.5" at the back and 1.3" at the front.
Spacers i hear you say, i did follow the gb thread on spacers but they seemed like hard work and you had to faff about with them!!
Is there anyone else that does them do we know!!
Old 01-27-2016, 03:52 AM
AnD3rew's Avatar
Not a fan. From the rear 3/4 angle it looks good, but from full side on it looks like the wheels are not properly centered in the wheel wells.
Old 01-27-2016, 08:09 AM
Dremorg's Avatar
I do like it lowered but I also notice what you are saying. Wonder if that is just Timbos car or if others look the same way. Also wonder if it will be detrimental in any way.
Old 01-27-2016, 08:12 AM
Foosh's Avatar
I think the H&R drop is a little too much on this car. I prefer the look of the Velocity drop, which a little less than 1" all around.
Old 01-27-2016, 08:17 AM
Unhingd's Avatar
With the spacers, I think it looks perfect. (If I thought otherwise, I'd change it back.)
Yes Jay, photo taken just a few moments ago in an alternate dimension.
Old 01-27-2016, 09:19 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
I would just point out that taking the picture with a wide-angle lens could cause that effect. In general, standing further away and using more telephoto reduces distortion, if that's what we're seeing.
Just a thought.
Old 01-27-2016, 09:31 AM
superq7's Avatar
I'd be worried about the speed bumps I've grazed my standard car quite a few times.
Old 01-27-2016, 09:45 AM
Unhingd's Avatar
oddly enough, I scrape less now than I did before the lowering. I attribute that to the differential lowering (1.5" rear vs 1.25" front). The car doesn't point down as much as it used to (and sits more level). Maybe I'm just more observant of the roadway topography now.
Old 01-27-2016, 09:47 AM
Foosh's Avatar
My money is on this.
Old 01-27-2016, 10:27 AM
ImNotFamousAnymore's Avatar
Looks good but +1 on this
Old 01-28-2016, 01:11 AM
AnD3rew's Avatar
I would be tempted to put spacers on mine without lowering it except they are illegal here.
Old 01-28-2016, 08:53 AM
TXJagR's Avatar
After reading this thread, as well as all the other wheel spacer threads, does anyone have all the specs for the FType so I can order so custom spacers? All the spacer threads seem to require grinding down the studs, or have some minor issue with the spacers...
What dimensions are required to NOT need any grinding of the studs, what is the proper hub bore, and what are the specs on the factory studs?
Old 01-28-2016, 09:20 AM
Foosh's Avatar
The problem is you'd have to go with wider spacers than 15mm to avoid the need to grind down the OEM studs. However, 15mm is about the max width one can go (with the OEM F-Type wheel offsets) before you start showing tire outside the fender lips. The studs are about 1-2mm too long to work with OEM wheel offsets and 15 mm spacers. Thinner spacers would be worse.
It also probably depends upon which wheel you have. We know the problem exists for 20" Gyrodynes and 20" Tornadoes, but I haven't seen any experiences posted for other OEM wheels.
Old 01-28-2016, 10:53 AM
Unhingd's Avatar
+1. Depends entirely on the how much of a recess any particular wheel offers for the stud to slide into. For the 15mm spacer and the Gyrodyne wheel you need to grind 2.5mm (3mm to make certain). That means you need 18mm spacers the avoid grinding studs (which is a royal PITA). At 18mm, I think the top of the wheel opening will still cover the entire tire width but you may not have sufficient space to accommodate full suspension compression if lowering springs have also been installed.
Quick Reply: Lowered my R...
