Lowering Options for SVR
The following 3 users liked this post by mlebofsky:
Ride is almost the same. Hard to compare now that I have upgraded tires... Cornering is slightly flatter.
Not home, so don't have the specifics on lugnuts, lugnut washers and 10mm adapters. Pm me and I'll be sure to get that to you over the weekend.
#28
Please post this info. Lots of us are looking for those lugnuts.
- Gorilla 73137BC lug nut Gorilla Automotive Products
- McGard 78713 Crager style washers (the washers that come with the Gorilla lugnuts deform a little, these are thicker/harder and hold up better. You loose a turn on the stud, but I believe I have plenty.
I just double checked and this combo allows 10 turns onto the stud.
Keep in mind my wheels require a flat mag style lug nut. YMMV.
Have held 92lbs for the past 2k miles.
I wish I could have found the washers in black, but to no avail .....
Liability jargon: Do not try this at home. I do not endorse this for others, but they have worked great for me.
Tork Monster (10-17-2018)
#30
#32
Spoke to a few vendors today and looked up a lot of websites on lowering springs. I am an advocate for KW, since I installed the full coilover system on my SRT8 in 2007 and they have been fantastic. Adjustable in height and rebound rate (not on the fly), and guaranteed for life. I was looking only for the H.A.S. spring kit for the Jag, as I wanted to retain the adjustable OEM shocks. I finally called KW US directly and they got some good info. Problem is the KW springs only lower a max of 20mm. I want more than that, and I wouldn't feel comfortable cutting KW springs because of their unique design (they would have allowed more adjustment if they thought it was safe)
Here is what I found:
MANUFACTURER .........Lower Front.... Lower Rear.....Cost.......... Link
KW Suspensions..............0.8"................ 0.8"......... $1099....... https://www.kwsuspensions.com/catalo...lt/?q=25331005
Eibach.............................0.6"........... .....1.0"...... $533-$563.. https://eibach.com/us/i-7874-pro-kit...4-springs.html
H&R ...............................1.3"............... 1.3"........... $382..... https://www.carid.com/2016-jaguar-f-...er=1&sub-model[DriveTypeName]=AWD+%28All+Wheel+Drive%29
Velocity AP......................0.86"............. 0.86".......... $695..... Jaguar F-Type R AWD Progressive Rate Lowering Springs
My confidence level in these manufacturers is in the order I listed them. I had never heard of Velocity AP before this forum, and zmoothg's issues with VAP (above) concern me. However, many others were very pleased with the VAP progressive springs.
H&R is the least expensive, but lower the car more than I prefer, and some have said these are stiffer than others.
I may go with Eibach, and cut the front springs a tad to increase the front drop. I don't know if the Eibachs are progressive though; their pics show a progressive spring but that could just be a stock photo.
I have to think this one through more.... any comments would be appreciated.
#33
H&R ...............................1.3"............... 1.3"........... $382..... https://www.carid.com/2016-jaguar-f-type-lowering-kits/?filter=1&sub-model[DriveTypeName]=AWD+%28All+Wheel+Drive%29
#35
#36
good to know. I have 15mm on all sides. Hoping like hell the KWs fit!
#37
I'm also contemplating the KW HAS for my '16 R. Did you run into difficulties removing the OEM shocks' (1) dust covers and (2) spring perch? Or did they come off without issues using hand tools?
And how is the ride? Any undesirable effects (eg bouncy / pogo effect) from the new spring rates on stock dampening, or improved in every aspect?
Bill
#38
Hi mcphill,
Bill
Bill
I don't experience any negative ride effects. I do still bottom out on the driver rear on big bumps, may still raise that corner a turn or two.
Bierry (10-10-2022)
#39
The rears are still on but the springs caused problems with my front struts and I had to get the whole front strut assembly and springs replaced and now the front is back to stock.
#40
