LSD option on 2016 Base Coupe ?
I skipped the depreciation cliff and bought my 2016MY Base after the previous owner and the Monroney sticker disappeared en route and cannot be reprinted according to JLR USA.
I ran my VIN# through Topix and came up with these options on the build sheet:
LSD WITH TVBB
AMBIENT LIGHTING-CONFIGURABLE
SEATBELT - PIMENTO RED
BRAKE CALIPERS-RED
So I clearly don't have red seatbelts or red calipers and there is no setting I can find for the ambient lighting (although some say some CCF tweaking makes it available to all cars).
So was it ever an option to order a 2016 base coupe with the LSD ? Is there any way to tell by looking at it ?
I guess maybe someone ticking the boxes in Topix was having a bad day...but curious nonetheless....
LSD WITH TVBB
BRAKE CALIPERS-RED
PM me your last 6 six of the VIN. I can get you a solid answer. But no, it was never an option. TOPIx might not correct. I'm puzzled by the TVBB as thats a feature that will come standard on all F-TYPEs for 2018MY.
I have a base coupe and it says:
"OPEN STYLE REAR AXLE-STD DIFF"
Nope. There's two different part numbers. One is a single color LED for the non configurable cars and the other is a two color LED for configurable cars.
I'll have to look again...
EDIT
Ah yeah, the lights in the door casing are either single or dual colour.
But I suppose it's just a matter of swapping those over, can't imagine that there would be any wiring differences.
EDIT AGAIN
Those dual-LED lamps are fairly cheap, like $25 each, so would be worth a go.
OK, confession time - driver error. ONE character different from my actual VIN still got me a car with the same specs (mostly) and the right colour but it wasn't mine....Topix appears to have got it right, although I can see the original owner swapped out the 20" Black Cyclones for the 20" Gyrodynes sometime/somehow. Which is nice.
As you were folks. Nothing to see here, move along.
