luggage compartment
Not sure whether the coupe is same as the vert in having an "emergency" interior trunk release.
Doe not make much sense in the vert as you can barely fit a hamster in there.
But if you have the interior trunk release you might check to ensure it is not somehow obstructed in the "open" position.
Cluck (08-14-2021)
We do everything we can to protect our hamsters!!!
![Icon Bowrofl](https://www.jaguarforums.com/forum/images/smilies/icon_bowrofl.gif)
![Icon Wub](https://www.jaguarforums.com/forum/images/smilies/icon_wub.gif)
More seriously
Does the luggage compartment not LOCK, or not LATCH?
[QUOTE][Do you have keyless entry? Try the trunk with the fobs a long way away ..../QUOTE]
^^^ This... get those fobs a LONG LONG way away. Or shield them by placing them them in your fridge.
Also, replace the batteries if its been a couple years.
If its a latching issue, a few drops of a light oil on the latch pawl might do the trick.
How are you testing that it's not locked? Are you keeping the fobs a long way away? If you have a fob close by you will always be able to open the trunk with the under-trunklid button (assuming keyless entry). Or is the remote app reporting the trunk is not locked?
Carbuff2 (08-15-2021)
EDIT: I should have refreshed the page before I replied. D'oh!
schuss (08-17-2021)
schuss (08-17-2021)
