Maintenance costs
Hi all, I have a 2016 Firesand convertible. My annual (12 month) service is due. My cost is in the $600-$800 range dependant on whether a pollen filter is needed or not. Synthetic oil/filters etc. Do you guys feel it is imperative or necessary that only a certified Jaguar technician do this?...I have a local European specialty shop that could do it for less...just want your thoughts...Its not really the cost (although it wont hurt if its cheaper) but rather the convenience as my Jaguar dealer is a 2.5 hour drive away...
Thanks in advance for any comments...
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Thanks in advance for any comments...![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Jaguar 5W20 Special Tec Oil Change Kit - Liqui Moly LM2663 | FCP Euro
![Amazon.com: Motivx Tools MX2325-US 88.5mm / 90mm 15 Flute Precision CNC Machined Oil Filter Wrench Compatible with Land Rover and Jaguar 3.0L and 5.0L Gas Engines : Automotive](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
![Amazon.com: Premium Guard Cabin Air Filter PC9381 | Fits 2003-15 Jaguar XKR, 2007-15 XK, 2012-15 XKR-S, 2014-22 F-Type : Automotive](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
The following 5 users liked this post by skizot:
Ftypekyle (02-11-2023),
GeorgeIII (01-10-2023),
OzXFR (01-10-2023),
Rat Fink65 (01-10-2023),
uncheel (01-10-2023)
If you have a competent shop that will work on your car, skip the dealer - especially on routine maintenance items.
Things like the cabin air filter will take you 30 minutes - but only if you take a 25 minute break. As suggested, get an oil vac and DIY.
You didn't state your overall mileage, but it might be time to check on brakes. Do the fluid change every 3 years, per the manual, but
again is another case you can skip the dealer. Think about switching out the brake pads before they're due and look at Porterfields.
If you don't push the job off too far, you should be able to skip the discs (but your friendly local dealer might well say you "must" do
them all at once. Nah.
There are definitely things that your local shop is unlikely to touch - particularly if it involves the electronics and/or needs JLR test equipment
355rockit (01-11-2023)
Rat Fink65 (01-11-2023)
I was initially a little nervous about working on my cat, but have recently completed the work you mentioned. As folks have said, you can source the tools and consumables easily, and the actual jobs are easy. Pollen filter took maybe 3 minutes, oil/filter change maybe 45(including a drive to O’Reilly Auto Parts to dispose of waste oil and used filter).
You can source all the materials for your car in Canada at
https://germanparts.ca/
Just put your year and model in.
The most important point is the oil meeting JLR specs....That I would not trust the independent to source properly as there are only a few sources.
gavinw35
05-19-2012 06:37 AM
