Manual shift delay
Drilling out the valve really did nothing for the slow hookup shifting from 1st into 2nd. The issue turned out to be a bad clutch design. During the 3.5 years of MT production, Jaguar issued 4 generations of clutches and 2 generations of flywheels. I now have a gen 4 clutch, gen 2 flywheel and a fully functioning clutch delay valve. It all works like a charm.
I'm getting more used to my '16 V6S and I'm feeling that the 6MT is a bit finicky to nail down. Driving around town and letting the upshift rev-matching work is perfectly smooth, but if I really quick shift the gears I can hear the clutch slipping. It's almost as if the revs don't drop fast enough before I engage the next gear, so there is some disparity between where the RPMs should be and where they currently are, leading to this slippage.
I am by no means an expert manual driver, but my E46 never felt this way. The flywheel would spool down predictably and it seemed to be perfectly happy quick shifting through the gears at any RPM. Perhaps it was the throttle cable difference.
Is this what you guys are talking about with the pre-4th gen clutch?
Flywheel is too heavy on this car, if you don't rev match or bang shift it (don't recommend, gearbox won't take it for long) then you can feel a bit of residual lurch. You need to be a really fast shifter to experience this. However, 9 out of 10 cases when people complain about shifting it is clutch slipping.
slipstream (07-16-2020)
Well the fact Jaguar is on its 4th generation of the clutch and 2nd for the flywheel says a lot.
Its gotten to the point that I prefer to shift with the rain/snow software turned on.
It goes off warranty in Sept. if it doesn’t become a hazard I don’t see a dealership jumping in. I understand the position they are in.
When it goes I will have a clutch built for the engine out of a shop in CA that does it for a business and match to the latest factory flywheel.
Got to wonder who in jaguar was running the drivetrain design/specs. Seems whoever it was too young to experience driving a car with a clutch or failed the required course in differential calculus.
My 2016 has 18,000 miles.
The gen 1 and gen 2 flywheels look identical, and though I didn’t weigh them, they seemed to weigh roughly the same.
Thank you for the feedback, it is definitely a goal of mine to get the 4th gen clutch in the future.
I know speaking of Corvettes here is one thing, but I have to say I considered buying a used 7MT Carrera as well but ultimately went with the F Type.. I wouldn't think the Porsche box would have any engineering shortfalls.
I can't say anything though, I knew this coming in. A price to pay for this car's beauty I guess! I'm still happy with my choice.
