Manual Transmission Fluid
Did a search and could not find any information on the subject. Has anyone changed their 6MT transmission fluid? Is it even needed? I understand typically gear oil is used for many manual transmissions.
I have some time this holiday season and will be doing a few fluid changes, thus am curious.
Maintenance
DESCRIPTION INTERVALS Normal maintenance Filled for Life Severe duty maintenance Change the fluid at 150,000 miles, 10 year intervals.Capacities
LITERS Transmission Fluid 1.2Lubricants, Fluids, Sealers and Adhesives
CAUTION:Use only Pentosin FFL-3 Manual transmission oil. Use of any other fluid may result in a transmission malfunction or failure.
DESCRIPTION SPECIFICATION Manual Transmission fluid GX73-M1R564-AA
Input shaft Grease GX73-M1R561-AA
Metal surface cleaner WSW-M5B392-A
High temperature grease Molecote FB180
The following 2 users liked this post by Rummy636:
Carbuff2 (12-22-2021),
takeapieandrun (12-22-2021)
I would change it...but I'm **** about maintenance.
Some manual transmissions do best with specific friction additives (looking at Honda, here). But on those, frequent fluid changes even with aftermarket brews keeps syncros shifting smoothly.
I found some references to using Ford full synthetic MTF, also Pentosin FFL-3.
I'm sure someone with better SEARCH skills will find more details...once you get the part number for Jaguar OEM fluid, you could search THAT.
EDIT: Like rummy636. HeeHee.
I got some oil at the same time I got some for my differential. The one listed by Red Line is their DCTF. I cross-referenced it at the time on their OEM Compatibility link with the specification from ZF's website for the transmission.
I have not yet changed it, although I did change the diff oil.
A change interval of 10 years/150k miles is too long for me with the engine running closer to the rated torque limit of the gearbox. I just didn't get it done before the weather turned, and with needing to work in the driveway it's going to wait for a bit. At only 45k miles I'm sure things are OK waiting for spring. I'm not driving nearly as much these days.
I also have several DIY's on here for the Transfer Case, and Diffs.
Good luck...And Merry Christmas...
DC
So I went down the 'oil thread' rabbithole, mostly on various BMW forums. Seems like Pentosin FFL-3, which is also used by Porsche PDKs, is equivalent to BMW MTF LT-5 (also stated by ZF). There seem to be many OE replacements from various manufacturers (Amsoil DCT, Redline DCTF, etc) for these two, which are <$20. Although for a minor savings, might as well go with the ZF recommended Pentosin.
Since I'm doing the work myself, its STILL better to spend a couple bux extra on factory parts.
Especially with fluids of unknown friction characteristics...I am skeptical of "Jack-Of-All-Trades fluids.
If I had an automatic I'd be more inclined to use only the specific, manufacturer's recommended fluid, but a manual transmission is a more straightforward mechanism. I'm confident the Red Line equivalent will do the job, and still have some residual loyalty to Red Line from my racing days.
