Manual Transmission panned
Independent of this or any review - positive, negative, or even neutral - I have little doubt (and based on your thoughtful - and if you ask me, "proper" - criteria) you will be. Good luck!
Jay, as you guess, I am not worried. Overall, the V6s manual has its shortcomings which I intend on addressing. Out of the gate, it sits too high, has a long shift throw and is slower than my tuned MINI. If I can't get it to my liking, I'll give up and throw a Tremec 5 speed into a '15 R. Now that jag makes the manual, all the trim pieces are available to do a conversion, including the pedals. (However, I'm guessing I'll get the S to my liking)
It's a psychosis some of us have. My Land Cruiser has 3 gear boxes: a 4 speed transmission, a 2 speed transfer case and a 2 speed splitter for a total of 16 speeds. Please don't make fun of the behaviorally challenged.
#28
While I defintely concur with you Tar1018 that the auto is brilliant (I'm exclusively in Dynamic Mode using paddle shifters 100% of the time) - I wouldn't have it any other way (and I too enjoy the occasional MT) - we've had this discussion here before with a dedicated group of MT devotees. Power to them I say.
Hopefully by the time I am ready to do this it will be a commonplace modification.
Meanwhile, I am still hoping Jaguar gets around to making manual shift V8 models. If the transmission just needs a little beefing up it seems like better bearings, stronger shafts and hardened gearsets for the one in the V6 would be possible for a price. I have already been assured the software can be tweaked.
#30
ZF already makes the stronger gearbox. With any luck, the bellhousing will swap over. Or it's the same. But the gear ratios might be wacky.
Cars | 6-Speed Manual Transmission - ZF Friedrichshafen AG
#31
#32
Ah not quite, the "bigger" S6-53 6-speed is only rated to 600Nm, the 5.0L S/C engine is putting out 680Nm in stock form. So no, it can't handle the torque.
#33
#34
The later C6s (after 2008) moved to the T-6060 which can handle more torque and was considerably smoother. The C7 is now the 6070, which is a 7-speed box. It sounds like the T-56 "Magnum" must be an upgraded version of the old T-56.
Also, for years, Corvettes have had the trannies mounted just forward of the rear axle, to balance the car. Do you know the weight difference between the ZF box and the T-56?
#36
Foosh (04-12-2015)
#37
Perhaps a somewhat more realistic view of the 6 speed here
First Drive: 2016 Jaguar F-Type Manual and AWD
Orkney
Orkney
OzRisk (04-18-2015)
#39
Raise the ground clearance, throw on AWD... it's turning into a high performance, 2 passenger crossover. As B.B. King would lament:"The thirll is gone". Cherish your RWD Rs.
#40
I SERIOUSLY doubt the thrill is gone, and I've watched a few test drive videos of the 2016 AWD. Nobody (other than this one article) seems to think anything bad about the new AWD system. Add to that, the extra 1/2 inch or so of ground clearance is just what I needed to not scrape getting into my driveway.
I still want to see a comparison test on a closed track, with one driver doing back to back laps with RWD then AWD...
