Manual Transmission panned
Old 04-11-2015, 03:37 PM
RickyJay52's Avatar
Received 1,601 Likes on 861 Posts
Originally Posted by Orkney
I am not going for the fastest or most fuel efficient. I am buying the ability to enjoy an F-Type with interaction between throttle, clutch and gearbox. As long as it's reasonably fun to drive and has decent thrust, I will be quite happy.
Independent of this or any review - positive, negative, or even neutral - I have little doubt (and based on your thoughtful - and if you ask me, "proper" - criteria) you will be. Good luck!
Old 04-11-2015, 04:46 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Jay, as you guess, I am not worried. Overall, the V6s manual has its shortcomings which I intend on addressing. Out of the gate, it sits too high, has a long shift throw and is slower than my tuned MINI. If I can't get it to my liking, I'll give up and throw a Tremec 5 speed into a '15 R. Now that jag makes the manual, all the trim pieces are available to do a conversion, including the pedals. (However, I'm guessing I'll get the S to my liking)
Tar1018's Avatar
Why anyway. As much as I might think the manual would be cool, the auto is awesome.....
Old 04-11-2015, 04:59 PM
Unhingd's Avatar
It's a psychosis some of us have. My Land Cruiser has 3 gear boxes: a 4 speed transmission, a 2 speed transfer case and a 2 speed splitter for a total of 16 speeds. Please don't make fun of the behaviorally challenged.
Old 04-11-2015, 05:07 PM
DuhCar's Avatar
You're too shifty.
Old 04-11-2015, 05:13 PM
Unhingd's Avatar
Originally Posted by duhcar
you're too shifty.
Old 04-11-2015, 10:16 PM
RickyJay52's Avatar
If anyone can do it - make it precisely the way they want - it's you. I have faith in you my manually oriented friend.
  #28
Old 04-11-2015, 10:19 PM
RickyJay52's Avatar
While I defintely concur with you Tar1018 that the auto is brilliant (I'm exclusively in Dynamic Mode using paddle shifters 100% of the time) - I wouldn't have it any other way (and I too enjoy the occasional MT) - we've had this discussion here before with a dedicated group of MT devotees. Power to them I say.
Old 04-11-2015, 10:33 PM
Nookieman's Avatar
This is the big advantage of the production of the V6S manual to me - parts availability for a V8 conversion. That is my long term plan for my V8S.
Hopefully by the time I am ready to do this it will be a commonplace modification.
Meanwhile, I am still hoping Jaguar gets around to making manual shift V8 models. If the transmission just needs a little beefing up it seems like better bearings, stronger shafts and hardened gearsets for the one in the V6 would be possible for a price. I have already been assured the software can be tweaked.
  #30
Old 04-12-2015, 12:05 AM
MagnumPI's Avatar
ZF already makes the stronger gearbox. With any luck, the bellhousing will swap over. Or it's the same. But the gear ratios might be wacky.
Cars | 6-Speed Manual Transmission - ZF Friedrichshafen AG
  #31
Old 04-12-2015, 01:32 AM
Nookieman's Avatar
Good to know. This would make the ultimate F-Type. Also, lame excuse as to why Jaguar isn't making manual V-8 cars if ZF is already building a manual box that can handle the V8 torque.
  #32
Old 04-12-2015, 03:13 AM
Received 4,454 Likes on 2,426 Posts
Ah not quite, the "bigger" S6-53 6-speed is only rated to 600Nm, the 5.0L S/C engine is putting out 680Nm in stock form. So no, it can't handle the torque.
  #33
Old 04-12-2015, 07:02 AM
Unhingd's Avatar
I was looking at the ZF alternatives as well, but As Cambo says, none are up to the 680 Nm of the R. The Tremec T-56 Magnum is the only manual at 950 Nm I know can handle the full potential of the R. I believe they have a bell housing to fit that engine.
  #34
Old 04-12-2015, 12:44 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
The later C6s (after 2008) moved to the T-6060 which can handle more torque and was considerably smoother. The C7 is now the 6070, which is a 7-speed box. It sounds like the T-56 "Magnum" must be an upgraded version of the old T-56.
Also, for years, Corvettes have had the trannies mounted just forward of the rear axle, to balance the car. Do you know the weight difference between the ZF box and the T-56?
  #35
Old 04-12-2015, 01:29 PM
ApolloBeachRetiree's Avatar
Originally Posted by Stohlen
I'd also like to know how a manual transmission cuts almost a second out of the zero to sixty time... But generally I tend not to take articles too seriously when they can't even get the model year right.
Maybe the author has not driven many manuals. You never know.
  #36
Old 04-12-2015, 03:08 PM
Unhingd's Avatar
The T-56 Magnum is the aftermarket name for the T-6060. At 135# dry, it's 21# heavier than the ZF-8HP70(H).
Foosh (04-12-2015)
  #37
Old 04-18-2015, 05:42 PM
Orkney's Avatar
Perhaps a somewhat more realistic view of the 6 speed here
First Drive: 2016 Jaguar F-Type Manual and AWD
Orkney
OzRisk (04-18-2015)
  #38
Old 04-18-2015, 06:16 PM
OzRisk's Avatar
The previous rear-drive car might have been a hilarious handful at the limit, but this one is just plain unpredictable.
They weren't exactly glowing in their comments in the AWD in the first part of that article.
  #39
Old 04-18-2015, 06:29 PM
Unhingd's Avatar
Raise the ground clearance, throw on AWD... it's turning into a high performance, 2 passenger crossover. As B.B. King would lament:"The thirll is gone". Cherish your RWD Rs.
  #40
Old 04-18-2015, 06:49 PM
TXJagR's Avatar
I SERIOUSLY doubt the thrill is gone, and I've watched a few test drive videos of the 2016 AWD. Nobody (other than this one article) seems to think anything bad about the new AWD system. Add to that, the extra 1/2 inch or so of ground clearance is just what I needed to not scrape getting into my driveway.
I still want to see a comparison test on a closed track, with one driver doing back to back laps with RWD then AWD...
Quick Reply: Manual Transmission panned
