Manual V6S vs. R AWD
Hi all - I'm buying an F-Type and I've found two vehicles and am completely torn. I have a $42k Manual S and a $52k R. Both are the same years and similar miles. Also have similar options.
I would love to own a manual and they're hard to find; but I also really like the R and all its craziness.
Any help would be greatly appreciated!
I bought an R, but I was pulled heavily to the 6M. The only reason I went with the R over the 6M was I would deal with a bit of stop and go traffic on my way to work. With all this work from home these day, I've been craving a 6M.
Having said that, the ZF tranny in my R is phenomenal. It really comes down to ego. A 6M with the lower pully and a tune is something to consider...
ferrral (03-19-2021)
Really depends on your driving style. The clutch and manual setup on the manual F-TYPE does not encourage spirited driving. The throws are long and a bit sloppy. If I recall, Jaguar went through 3 or 4 clutch revisions due to the amount of complaints related to slipping and premature wear. Fun fact, the transmission is the same one used in the BMW 1M and the earlier clutches were made by Volvo.
One of the member here, Unhinged, is our resident F-TYPE manual guru though. I'm sure he'll chime in.
I sought out a manual because I wanted to move a shifter around and have 3 pedals of fun. I also happen to think the V6 sounds better than the V8 but I realize lots will call me crazy for that. On top of those reasons the V6S being cheaper AND 380hp being to me just an absolutely insane amount of power, I'm happy.
Now I was also coming from a ~150hp Impreza so if you are used to driving with higher powered vehicles then maybe you need that V8 in your life.
Uncle Fishbits (03-25-2021)
The Gen1 clutches have pretty much all exploded by now. The latest is holding up well. Feeling is a little vague compared to some I've driven but given the safety features to protect the driveline, it's as expected.
The shifter throw is a bit long but Lance (Unhingd) has a solution for that. I've got the first version of that but the manufacturer discontinued them. The later version involves modifying the stock shifter. He has a local machine shop that does it, and I expect has a spare OEM shifter to modify (I sent him my original, but that's surely in someone's car by now) to avoid having a car off the road.
The tune and pulley combination definitely gives more power, and I'm quite pleased I did it. I did the tune at 10K miles, the pulley 32K miles after that.
Is it better or worse for spirited driving? Depends on where your spirit takes you. As Vik notes, the ZF8 is very, very good, and even with a V6 it would be faster than the 6MT. I can't shift anywhere near that fast. If you're a stoplight drag kind of person, the R is a better choice. For the twisty country roads I like best, I'm glad I got the 6MT. I'm not racing, and it adds to the fun.
I want something flashy, fast, and fun. Just not sure if I need the V8 or if the manual would be more fun.
Thanks for your post.
Yeah, that would be the first thing I would do would be a tune and pully. This would be essentially a weekend car as I work from home and its a pandemic, so only driving for fun and not really "dailying it". I just don't want to regret not getting an R. Were you able to drive both?
That said, the V8 power is intoxicating. If I didn't have an abundance of backroads at my disposal, I might have chosen differently. These questions often elicit at least one response of "if you don't get the V8, you'll regret it later."
EDIT: Forgot to answer the other question. Tune only was easy. Buy it and when the handheld device shows up, extract the stock file, email it to VAP and wait for the modified one. Load that in and off you go. There are a few things to watch out for, e.g. battery voltage, but easily manageable. Adding the pulley is also straightforward, more so if you have a lift. I don't, so did mine on ramps. Call it a Saturday morning if you've got the right tools and know how to use them.
Memory does serve - that's why AWD cars have a different bonnet/hood design than the RWDs - RWD has the vents close together near the windscreen/shield while the AWD has them further apart and more towards the front.
I drove most available variants before ordering my 6MT, but not any AWD. One of my reasons for the 6MT is that it's lighter, especially in the nose. It's still not light, but even the RWD Auto V6 vs. V8 I could feel the extra weight up front. The AWD adds even more, and if memory serves, raises the engine by half an inch. I deliberately chose my test drive route to include a few lively side to side transitions to help pick out the differences.
Luc Lapierre (03-21-2021)
Either way you go, you're going to be buying a great car. Good luck on the decision.
This really does go to everyone's personal preferences. Having driven British sportscars my entire adult life I test drove an F Type automatic and thought, geez, I can't drive one of these around by just stomping on the accelerator. Regarding the gearbox, the throw on the gears as equipped is a bit long but I wouldn't call it sloppy. With a short shifter installed it is a top-notch gearbox to the point that my daughter's father-in-law who has owned several manual M4s (I believe with the same Z6 gearbox) told me upon driving my car that it was a lot more fun than an M4. Additionally, everyone has their own definition of the exhilarating car experience, but mine has been on the track or getting on the expressway (safely) by coming out of a turn in 2nd at 20 mph and going to 70 mph to slam it into 3rd to got to about 100 - 110 mph while listening to that supercharger scream (this car makes a very satisfying all around sound while doing that).
