Map Update
Originally Posted by polarisnavyxj
I seriously haven't considered data for ten years. In fact I use my phone as a hotspot for my laptop when I travel when airports get so greedy they don't offer wifi.
If you shop around you can get a unlimited plan for $69.
I've tried switching a couple times but always go back to Verizon because their coverage is objectively better at home and when I travel.
I must be older...I only had a theodolite. No Interstates, we had to blaze our own trails. (...and then there was that 10 mile walk to school...)
There are about 6 different routes I can take depending upon traffic conditions, and Waze usually sends me the fastest way based upon traffic. The car's nav system almost always tries to send me on the shortest route based upon no traffic, which is often the worst way to go during rush hours.
Like I said above, if you don't routinely drive in urban gridlock, you either don't need it or any old Nav system will do.
You probably had to build survey towers too.
https://en.wikipedia.org/wiki/Great_...etrical_Survey
#30
#31
#33
I was on a one week trip throug parts of Germany (to Nurburgring) together with several Ferrari's (430, 488, 599), Porsches (GT3 RS, GT2, Turbo S), BMW M4 and Mercedes E AMG 63, and we had to manouver through some larger cities in high trafic to find the quickest way to the hotels.
We split up in small groups/singels as it was impossibel to stay together due to the trafic and many trafic lights. All of us had the hotel adress in our Satnav systems.
I always ended up first to the hotels, and the only one I can give that credit to is the F-types functional Satnav system. It has it's flaws, is a bit slow - but it worked better than the systems in any of the other sportcars.
I don't see how I can complain
#34
When I last went through this with my Acura, their provider (Alpine) had the information on their website. I didn't see detail on the Jag link, but there was a FAQ link and a CONTACT US form for questions. I'd start with that.
Mbourne (06-17-2016)
#36
#37
#38
I think the main difference between Waze and car-installed, nav systems, that also have the capability of re-routing around traffic tie-ups, is that Waze has access to a lot more real-time information in heavily populated areas. For example, in the DC metro area there are always between 10-20K users driving w/ Waze running at any given time during prime daytime driving hours. All of those data are being continuously used by their system to calculate the fastest route. Because it has much more real-time data based upon many more users, it's more effective in providing the best re-routes around traffic jams.
Every now and then, I will run both Waze and the car NAV at the same time, and often Waze plots a different route, which out-performs them. Because the car systems don't have access to nearly as much real-time data, re-routes are often based upon something that happened an hour ago which is no longer relevant. Waze seems to recognize more quickly that traffic jams have now been cleared, as well as seeing more quickly that new traffic jams have occurred. The car-based systems more often send you on a re-route, which takes longer and is no longer necessary. My experience has been that they are also more likely to send you into new jams not yet recognized.
If you live in a more rural area with less traffic, the car systems usually perform equally well. Waze doesn't have an advantage in areas where it doesn't have many users on-line.
Not to mention knowing where the cops are. Objects on road. Stalled cars.
Man its just better.
We've got forum members trying to get through life without buying data? Id compare it more like HDTV, regular def is perfectly fine until you actually experience HDTV. Crunching data is fine until you experience unlimited. There was also a time when you monitored how many cell phone calls you made, further and to where the calls were made to. THOSE DAYS ARE LONG GONE.
mikelanzetta (06-19-2016)
#39
#40
What he said...
