Matching engine number?
Old 08-16-2024, 01:50 PM
Adam Deermann's Avatar
Default Matching engine number?
Hi,
is there a way to match the engine number to the car? I am wondering if the engine was swapped in the past.
regards,
Adam
Old 08-16-2024, 08:31 PM
uncheel's Avatar
Originally Posted by Adam Deermann
Hi,
regards,
Adam
You should see the serial number on a raised pad in the center of the engine block just below the head gasket surface. Check it against any documentation you got with the car. Otherwise, a dealer should be able to tell you if it matches the build.
Old 08-21-2024, 10:26 AM
macribor21's Avatar
You have a variant of the Ingenium engine, but not the 2.0 diesel which is the one with all the issues. Petrol ingenium engines are mostly fine.
jaguar1966$
E type ( XK-E )
02-10-2023 09:20 AM
Kenson
03-06-2022 06:03 PM
mu2rick
E type ( XK-E )
03-26-2018 09:24 AM
xj-c4.2
04-13-2017 11:44 AM
Gippsland
04-15-2013 05:11 AM
Quick Reply: Matching engine number?
