Memory saver when changing the battery
Has anyone ever used one of the 9 volt memory savers? You just plug it into the cigarette lighter while you change the battery and you don't loose your memory settings. I had one years and years ago and it worked. Not sure if this would work on our cars.
![](https://images-na.ssl-images-amazon.com/images/I/71Sq-GT81RL._AC_UL232_SR232,232_.jpg)
When I installed the CTEK pigtail in my 2021 F Type the only settings I lost were the auto up/down window functions and the electric hatch close button. Of course I only had the ground cable for the battery disconnected for less than a minute. The window functions were easy to reset and the hatch only needed to be closed manually to reset the electric button. I didn't lose any radio stations or the trip computer settings.
I suppose if you took more than a few minutes to install the new battery after the old one was disconnected you would lose some memory settings. The best thing to do would be to have the new battery fully charged in advance (check it as chances are that it won't have a full charge right off the shelf) and then make the swap quickly.
When changing the battery you could connect a charger (proper one, not a CTEK) or spare battery if you have one across the under hood terminals?
Is the idea here that you attach a 9V battery and when you plug in to the cigarette lighter the 9V from the battery flows into the car to keep the memory alive? But, if you did this, or some other similar hack, wouldn't that defeat the purpose of doing a battery disconnect to "reset" the car? I'm not an electronics guy, so please help me out here.
If this matters to you:
We lost our trip odometer readings when resetting the battery, they reset to zero. So write the numbers down if you keep track, for manual calculation of MPG for example.
Yeah you could just subtract total mileage for that calculation, but that requires using too much MATH!
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
