Meridian Audio System
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
My 770w system causes the doors to vibrate at moderate speaker volume. . Playing at about 25 on the volume scale, certain low frequencies cause something in the doors to vibrate. Have turned down the bass but it loses what the stereo is designed to do. I took it to the dealer and they said they tried another F-Type and it does the same thing. They said that there are no fixes from Jaguar so there is nothing they can do. Any ideas? I am calling Jaguar today.
I have the B&O too. It's pretty good once calibrated properly.
I think you meant the 380W base system, and I agree it doesn't take much to make it painful. I have to wonder why one needs so much power in such a small space, and after hearing all the gripes about the ''premium" system, am very grateful that my car has the base system. It sounds really good.
Having said all that, if Jaguar is going to offer all that power in such a tiny space, they owe it to their customers to engineer it so that it works without vibrating the panels off the car.
I have the 780w system and it sounds great.. no vibration and I play it loud at times, but not usually to the point of ear bleeding.
My only gripe is that when in the 'Meridian' setting the rear speakers are totally silent. So, I use the DTS setting and the surround is good, depending on source.
For instance the FM radio 'source' quality is variable from the perspective of the rear speaker coming in, even in the DTS setting....however, if I use an USB source or CD, the rear's are consistently in.
The car is garaged for the winter, in the spring I will take it to the dealer to see about the 'Meridian' setting not bringing in the rear speakers.
Lawrence.
Lawrence.
Have Dynamat installed in the doors. Any good auto audio guy will be able to help
http://www.dynamat.com/automotive-an...ynamat-xtreme/
slojotaa (04-17-2015)
Any good mechanic should be able to eliminate rattles regardless of the source (road surface or sound system). Removal of the door panels and liberal application of moleskin tape wherever components, panels or wiring harnesses meet will address that particular problem.
DuhCar (12-30-2014)
just need to get some dynomat put in
Everyone with the problem should write a review on Jags site and include it in it. For the US go here http://www.jaguarusa.com/all-models/...ews/index.html
I took delivery of my car 2 weeks ago and have none of these issues with the sound system. I have the premium system and it works great. No rattles, buzzing etc. and the sound from the rear speakers is fine. My car was built in November so maybe they resolved the issues by then.
Have the issues occured more in the convertible than the coupe as I have the coupe?
