Meridian Sound System...
Been jammin' on my 770 watt Meridian stereo system for past 3 years now. Sound awesome. But with my convertible, I've got the volume cranked up a little bit louder than normal. Now my 4" door speakers starting to rattle & making buzzing noise. Wondering if the speakers are coming loose from its enclosure & screws needs to be tighten, or if the speakers are starting to disintegrate & needs replacement.
Been checking out more info about this Meridian system below.
https://www.meridian-audio.com/in-ca...jaguar/f-type/
https://www.meridian-audio.com/media...t-a-glance.pdf
Does Meridian make their own speakers? are they quality / high end speakers? Or need to look at aftermarket brands replacement?
Meridian boasts about being rated #1 auto sound system, but I believe it only applies to their $3250, 1700 watts, 23 speakers system on the Range Rover:
https://www.meridian-audio.com/about...bile-magazine/
Sonic Booms: Putting 8 of the Best Car Audio Systems to the Test - Automobile
But doesn't apply to our measly 770 watt, 12 speakers on our F-type?
Dang.
I shoulda had dealer looked at the speakers when I was there for annual service last wkend.
If they took 1.5 hours for a simple oil change, Imagine how long it'll take for them to remove door panel to check. Most likely will have to order factory speakers since it's most likely not in stock, then more time to install...
Dang.
Wink, can u pls give us detailed steps to having your speakers replaced?
Sequence in calling dealer service dept, detailed issue, they ordered replacement factory speakers without u having to bring car in for checkup/inspection first?
How long for service? u waited, or have to leave car there awhile?
Received 3,266 Likes
I had the B&W surround sound system in my 2010 XFR (the 440W system not the full fat 1200W system) and it sounded great with zero speaker vibration regardless of settings or volume, I suspect you have the same system.
The 770W Meridian surround sound system I have in my F-Type sounds good with very little speaker vibration, but if I turn the sub setting way up I get some vibration on some tracks so I run it with the sub setting at 50% which is plenty for my tastes, not a fan of doof doof!
Sure. Had it in for regular maintenance last Thursday. The rep asked if there was anything else i wanted them to look at while it was in. I half jokingly said for the type of car it is, that stereo really sucks. He asked what I didn't like, and I stated that the bass sounded muffled, the treble was tinny and it rattled. Just bad overall sound. I've got a 2007 Civic daily driver and the stock stereo blows this one out of the water. So when i get the car back he told me they updated the amp, and to get rid of the rattle they will need to replace the subs. I was actually surprised because I wasn't really expecting it. Came back yesterday, they replaced both rear subs, it took about 1.5 hours (I work off of the next exit on the highway so I had them drop me at work and pick me up) and it does sound much better. Again, it's not the greatest but much improved.
Originally Posted by OzXFR
Pretty sure a 2010 XF has Bowers & Wilkins not Meridian, and JLR didn't switch over to Meridian until at least 2012.
The F Type system seems average sound quality to me - much better once the vibrations are reduced. But maybe that's the compromise of a sports car - not designed for acoustics
I plan to drive the car a bit longer to see if I can identify anything else before I take it in to the dealer, since they're about 50 miles away, on the other side of Phoenix, AZ.
TomP
05-31-2019 09:09 AM
ilkka suppanen
05-19-2019 10:09 AM
