Meridian speaker upgrade question please
So I have upgraded my rear subs and run them through a convertor and amplifier using the signal wire from the original subs.Sound is still Pony Now plan to take a feed from the 2 front 8inch speakers and run that through the additional amp then to my new subs
my question is do I need to put some kind of resistor on the original sub wires that I won't be Using Will the amplifier cut the output from the rear mids as well because of it thinking the subs are faulty as in not connected
You will most likely need LGD's (Load Generating Device) between the factory amplifier and the Sub amplifier to make things behave correctly. Gray LGD-60 would be the correct ones for a Meridian 380 system. If you don't use them thing get a little wacky as modern Class D amplifiers need to see a speaker load which is different than a amplifier hi level input. Some aftermarket amp and line level convertors already have this feature built in, if not they are cheap.
boultons911
11-17-2022 07:59 PM
thePest007
03-12-2017 02:20 PM
