Methanol Kit
Has anyone fitted a meth kit on these cars? I have used in my last 2 cars with big results. A very good friend of mine develops the kits for GN’s, Corevettes, CTS-V’s etc. anything with a power adder and surprised I haven’t seen anything after I searched on the forum for this. It’s a relatively cheap add-on with nice performance results. He added one to the Dodge Challenger hellcat and it added more hp than the Demon had.
Maybe I’ve missed a post on this so sorry if this is duplicative.
The OEM superchargers (on the V6,anyway) are pushing between 13 and 14 pounds, but with pulleys you can push them up to 20. Heat then indeed becomes the limiting factor, but you would need to address the heat before the airflow enters the combustion chamber.
In theory the 1320 (used in the V6) can reach 2.5 bar (36.2594 psi). In reality, the maximum pressure is a function of the supercharger rotational speed (manipulated with pulleys), and displacement f the engine.
The efficiency of the supercharger is based on the speed, with the 1320 rated at a maximum of 20,000rpm. Overdriving any supercharger drops the efficiency to the point where passive power losses, aerodynamic flow losses and heat will result in negative gains...It's a delicate balancing act and you want to find the correct size based on your final intake pressure and efficiency.
jackra_1 (01-03-2019)
Jeff in Tucson
06-12-2014 01:22 PM
1320racer
02-28-2012 05:45 PM
