Michelin Pilot Super Sport Tires
Would you please clarify what car, weight and tire sizes have you experienced this edge wear with? How much pressure and camber do you suggest with this tire?
I am most surprised because today's low profile tires have extremely stiff sidewalls in general where we don't have to worry about chewing up the edges and sidewalls. I generally consider up to -1.5 degree camber with cold tire pressures of 32-34 to be quite sufficient for cars that see hard street and occasional track driving on modern 20", 30-35 series tires.
Your post got me concerned because I live in an area where 90 percent of roads are tight and winding and I do like to take advantage of them. I would hate to see the edges wear off prematurely while the rest of the tire thread is still like new. I do have to deal exactly with that issue on my other cars with taller tire sidewalls and non-adjustable, close to zero factory camber settings.
The PSS on my XKR on the track are 38 PSI front and 36 rear hot. I have no problems with side walls and the wear characteristics on the track are perfect with -1.8 front camber and -1.7/-2.0 rear.
If I can find a picture after a track day on this PC I'll post them, I always take pictures and temps of the tires after each session.
Heres a tire from each corner after the third session of the day. This is from PBIR which is notoriously hard on tires. The left side takes the biggest beating o on this track as all the fast corners are to the right.
These tires also have 5k miles of street driving and another track day on them. They still look great and will see homestead next Friday.
axr6 (05-28-2014)
Out of curiosity, do you have saved temperature readings (outside, center, inside) for the front and rear tires? Just interested to see how the cambers are working at the track. Those tires indeed look fine.
I dont have the temps on this computer but will take a look when I get home. I know they were quite hot that day but stuck like glue... Very predictable tire that gradually slides as you pass the limit and doesn't snap back and upset the balance of the car when traction is regained. They make driving smoothly very easy, a really great tire.
My experience with the F-Type on track day wear is that the default factory setting for camber resulted in very even wear across the tire. I did not opt for the more aggressive camber setting offered by the tire shop (Stokes Tire/Santa Monica).
And I have found that hot tire pressures on all four corners of 32 produced the best results to my liking. Cold pressures of 26 on all four got me right there. I found the car to be tail happy on any higher pressure making it harder to get the power down out of the corners. Results may vary!!! LOL.
20x9 1/2 front and 20x11 rear and 265 front and 295 rear tires.
I'm sure your air pressure requirements are different. Hot tire presses will vary widely depending on track surface, ambient air temp, brake temp, direction of turns on the track, speed of turns, driving style, and 100 other things. You just have to find a pressure that you are happy with and measure it hot and after your happy with the suspension setup.
Are those wheels plus sized for the width of the tires??? They do look a bit oversized.
Monsters of Grip: Nine Summer-Performance Tires Tested - Comparison Test - Car and Driver
ungineer (06-03-2014)
Hey MaximA was reading through some posts on the F-Type and wanted some first hand track reliability info regarding engine, transmission temperatures and breaking feel. I live in FL and do want to use the F-type for track days at PBIR, Sebring and Homestead. I wanted to also know how many hard laps you can get in before you need to allow it to cool down? I have had 911 turbos and a GTR but was seriously thinking about a F-Type R that would have put up with some track days.
This was on a z06 at mid-ohio.
I was just trying to save someone a set of fronts if they drive on the track and don't already have a pretty aggressive air and camber setup, not trying to diss the tires.
I did stop using them as a track tires and switched to a less grippy BF Goodrich G-Force rival with a stiffer sidewall and a little more heat tolerance.
Max, when we getting on Iracing together lol!
PSS are a great tire and have lots of fans in the 997 world so I would suspect the same here. I did some track events in my Turbo S but used Pirelli Trefro R-Comps. Very sticky and very stiff sidewall tires that liked low pressures. (30-32 psi hot)
I do have a question for you other F-Types out there. Is there a way to see what the TPMS pressures are? I was unable to find the answer to this question in the manual.
On the track I utilized the Porsche TPMS screen exclusively to ensure I stayed under 32 psi. Each session I had to let air out to do so.
Thanks, Walt
Thanks, Walt
