Michelin Pilot Super Sport Tires
#41
This is mostly because its the only other tire available in the stock sizes, outside of a Conti track tire. I personally would prefer something other than the PSS, i've seen them chunk on the edges during hard cornering and think there are better options out there, but its gonna take time for manufactures to start making them.
Stohlen (06-04-2015)
#43
#44
I had those on my Nissan 350Z. They are a pretty good all around tire. Pretty quiet compared to some others I have tried. Good in wet conditions too. I never tracked them... (They are Z rated or better though)
The Z also has 300 hp, not the 550 of the new R Coupe...
#46
Read the fine print and exclusions in the contract. Mine will replace with like tire as long as they meet OEM specs. Im getting one replaced now with a stock P Zero, but once i wear them out and switch to Michelins, I am NOT buying certificates from the tire shop as I will still be covered for damages. They will not cover racing tires though, so no drag slicks.
Dremorg (06-08-2015)
#47
So I just ordered 2 x 305/30R20 Pirelli Pzero Corsa, throgh the Jaguar dealer, at $512 each I thought it was not that bad of a deal, in comparison to the regular Pirellis. I called the dealer to ask if they would fit, no one could give me an answer and the last guy that picked up the phone said he didn't know but as long as I pay for them he will install them.
I now am thinking I could have installed (4) stock size PSS instead for $300 more....
-Antonio
-Antonio
#49
#50
Had PSS's installed today and it is like a whole new car (stock sizes). The ride is a lot more composed, The handling limits are higher, the turn in is crisper. They are also not as noisy as the Pirellis. I would never have believed that there could be so much difference between 2 competitively matched tires, at least in this application. IMHO, the best upgrade you can make with this car.
Dremorg (07-29-2015)
#51
However, like you, I always feel like a new set of tires feels better than what I drove to the tire shop with. The mind plays tricks on you that way.
#52
I disagree that a break in period of hundred(s) of miles on any tire is necessary to get a feel for them. In my experience, in street use, tires only need to scuff up a bit, get the mold release off, and get some heat in them and they are good to go.
IMHO an hour on the new rubber should be more than enough seat time to start drawing comparisons, especially in warm weather. If the OP can tell a difference on day one that's valid from where I am sitting. By day five he will probably have forgotten what the pirellis felt like. The contrast is never going to be as fresh as it is on day one.
BTW, thanks for the input on the PSS option. With only three choices on tire rack it's nice to hear anything about tire options. I am still waiting to hear from someone who dropped the extra coin on the Continentals before I buy anything, but I am leaning away from OEM at this point, based on this thread and others.
#53
I appreciate the review as well, and I will absolutely switch to the PSS when the time comes.
#55
I am half tempted to go with pirellis or PSS at the rear and contis at the front. My thought is that with softer fronts all four might wear out at the same time, and the very slight under steer might go away. Then again, perhaps a performance alignment would work just as well.
#57
I put Conti on my '08 TT and really liked them. My SLK55 came with Merc specific Conti and they were great, more $$$ than DW. Rear wore out at 6k but that is the car more than tires. That said I'm putting PSS on Jag as soon as I can justify it. 8k and rears are starting to show wear. If you read Tire Rack survey it's a know brainer unless you go to track, then there many choices, but you sacrifice street comfort.
#58
I have switched back and forth between P-zeros and PSSs on 3 different cars and the PSSs have always and very noticeably out performed the P-zeros. In fact, as a result of my experience with these tires, I installed the PSSs after only 35 miles on the new car. Huge difference in handling, tire noise and ride comfort. Some of the handling improvement can be attributed to the Lower profile 20" PSSs (vs the original and narrower 19" pirellis) but the improvement in ride comfort with the lower profile PSSs is surprising.
#60
I really wanted to try the Vredestein Ultrac Vorti but the fronts were not available for another 30-60 days and I can't wait that long. Although the Pirelli P Zeros were not at the wear bars the tire was scary in the rain (16500 miles). Tire rack delivered extremely fast. Installed the Michelins this afternoon.
