Michelin pss for rear only
Hey,
Can I get some advice on changing the rear tires only?
My rear tires, stock pzeros, are not completely worn out, but I can justify changing them early. The front tires look like they've never been used, so I'm gonna have to keep them. Is it ok to upgrade the rear tires only, or are there negative side effects to that? Will I get the benefits of the PSS if I'm just changing the rear?
Do I just get the same tire size I have now?
absolutely no problem just changing the rear tires. you can get the same size or do the 305s in the rear. from what i've read they are stickier so you should get some better traction, but honestly I have no personal experience so no idea if you can tell the diff in "normal" driving.
Sizing is just to make sure it fits the wheel/car. Stock size is a good starting point, and as long as you are reasonably close to those dimensions than it won't mess with things like the speedometer. But heck, if you really wanted to you can run all kinds of crazy tires/wheel sizes. The car will then become crap (ride height too high/low, etc.), but it can be done. People mention the 305s because it doesn't really differ from the stock dimension that much. It's marginally wider so that helps a little, but it's more about the compound.
Generally, on dry pavement, the same tread/compound will offer more grip the wider it is. if you go with a wider (305) PSS you will definitely enhance your traction. (compound and width enhancement). Leaving the P-zeros on the front, you will experience more understeer (or less oversteer) than you are currently. Not a problem...you just need to adjust your driving accordingly
Tire change completed. Rear tires only replaced with PSS.
A few immediate thoughts:
- Grip seems a little better. Not as much as I thought it would be after all I've heard.
- Pzeros actually looked better on the car. They have a better shape, but I think they are also a tad thinner on the outer edge. It makes them blend perfectly with the rims, and the pattern looks better as well, but that last part is subjective.
- It turns out one of my rear tires, right side, was almost bald, especially on the inside. I had only taken a close look at the left tire before, and that one must have been at 50% when they removed it. Anyone have any idea as to how the discrepancy could be so huge?
1. Alignment for the rear has a negative camber so the inside will alway wear just a bit faster than the outside.
2. If you are a bit aggressive with your driving the right rear wheel will wear much faster than the left since you generally are taking far sharper right hand turns on the street than left and the inside wheel will be trying to spin faster than the car is moving unless the LSD is fully engaged.
Hello,
From a safety perspective I would recommend finding out whether either your front tyres or rear tyres are designed to work in a system of 4 tyres. Most high spec tyres these days are designed to work in harmony, i.e. same compounds.. same water disperse rates.. anti aqua-planing.. grip levels..
Hello,
-ve camber will cause the inner shoulder of the tyre to round off, but you would have to be running lots of -ve to wear the inner edge to the point where it's bald.
Even small amounts of toe out on the rear relative to the thrust axis will wear the inner edge off in a couple of thousand miles.
For reference, Alfa Romeo used to deliver cars with so much toe-out on the front that the inner edges of the tyres were shot in less than 5000 miles of road use.
