Michelin Sport 4S vs MPSS
Old 05-03-2018, 02:50 AM
diplomat's Avatar
It is maeasured from the moment when I released the brake pedal and I measured 0-100km/h, so 0-60 mph is even better, but of course some GPS timing equipment would be better.
This was with Pirelli PZERO which have very bad traction.
I think with Michelin Pilot Sport Cup 2 and Crank Pulley + ECU Tune I should be able to make 0-60 under 4 seconds.
  #182
Old 05-03-2018, 03:08 PM
UBI's Avatar
UBI
UBI is offline
The 100 km/h on the speedo are not real 100 km/h!!! ;-))
  #183
Old 05-03-2018, 03:13 PM
diplomat's Avatar
Sure! Everybody knows that, but still the time for 0-60 is less than 4,3 s and that is less than what Focus RS does and that was my point.
  #184
Old 05-03-2018, 04:21 PM
FR500GT's Avatar
Originally Posted by Cherry_560sel
I haven't dyno'd since installing the spray kit so its not official, but I was hovering around 475 hp with the other mods and I am jetted for a 175 hp shot distro.'d from 2800 RPM through 6500 RPM. Simple math tells me I am probably in the 600HP+ ballpark. First gear launches are pure heaven now. I start with a 20% hit and build up progressively through the first six gears. Don't know how much the 3.0 liter can take, but so far so good
Howe long have you been running at 475hp on your 3.0 V6?
  #185
Old 05-03-2018, 09:08 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
With 305/30-20 tires, the F-Type speedo reads true.
  #186
Old 05-03-2018, 10:47 PM
Cherry_560sel's Avatar
I think I ordered the tune from VAP around December of 2016 and the pulleys got installed around March of 2017...So I would guess I ran with those mods for about a year before installing the spray kit. Got the MPS4S tires in March of 2017 also.
  #187
Old 05-04-2018, 01:07 AM
FR500GT's Avatar
Good to know that it’s holding the power well!
  #188
Old 05-04-2018, 09:24 AM
UBI's Avatar
UBI
UBI is offline
With 20" 295 the difference are about 4km/h. PerformanceBox vs Speedo!
  #189
Old 05-04-2018, 06:17 PM
bjg625's Avatar
Retiring P-Zero's after 4.5 years and 16k miles. PS4S due in Wed. On 19's you can only go up 1/2 inch on rears so for $11 I said why not. Will update after install.
  #190
Old 05-05-2018, 04:10 AM
jaguny's Avatar
Are you going installing the rears (assuming 305's) on oem 10.5 inch wheels?
  #191
Old 05-05-2018, 06:25 PM
bjg625's Avatar
going on original wheels, problem was Michelin has yet to make a wider size that fits. Did a little after we reference michelin dealer site. They just don't have it yet. i think more options for 20's.
jaguny (05-06-2018)
  #192
Old 05-05-2018, 11:34 PM
Four years !!! wow...
  #193
Old 05-07-2018, 07:36 AM
Selko92's Avatar
Before I get myself some Michelins I will burn up these P -Zeros and be done with them.
  #194
Old 01-04-2019, 03:03 AM
4Holer's Avatar
PSS 305’s on the back, 265’s up front. A lot stickier and quieter than the original Pirelli’s.
JgaXkr (01-06-2019)
  #195
Old 01-06-2019, 05:20 PM
Tpaxc's Avatar
Has anyone run 295/25/20 on the rears? Curious how the height difference would look?
  #196
Old 01-06-2019, 05:57 PM
Unhingd's Avatar
that will be over an inch smaller diameter. To look right, you would need to under size the front tires as well. Also, the diameter difference front to rear would cause serious issues on the AWD cars.
  #197
Old 01-06-2019, 08:23 PM
Tpaxc's Avatar
Ah ok. I have a 2015 RWD
  #198
Old 01-10-2019, 09:39 PM
OpenF's Avatar
I've had the P4S's for about 14 months and almost 14K miles (~22.5K KM). They should probably last another 3-5 months with a corresponding 3-5K miles before I need a new set. The question then is going to be getting a set from one of my local-ish Jaguar dealers, like last time, or from tirerack.
  #199
Old 01-10-2019, 10:43 PM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
Why are you even thinking about where to get them from?
Log on to the Tire Rack site and check out their prices, then get a quote from the dealers for the exact same tyres, and then go with whichever is cheaper.
I will bet that the Tire Rack prices are significantly cheaper than the dealer prices, although you need to factor in the fitting cost as well (and maybe the Tire Rack shipping cost if any also).
  #200
Old 01-11-2019, 01:18 PM
Unhingd's Avatar
The dealers may not be able to compete with TireRack, but a good indy performance tire shops should be able to match those numbers after you factor in the M&B costs.
