Mina Gallery intake kit
#101
madmax1911 (08-17-2020)
#102
Lower Intake for Testing
Mina Gallery just sent me their new V6 lower intake to test (on them). I'll be installing it sometime in the next two weeks and will post my impressions. I had installed their upper intake over a year ago and am still impressed how it has improved the appearance of the engine compartment. I an hoping for a discernable increase in SC whine. Installation instructions attached.
#103
#104
They should the TheRock88 to do their instillation PDF's, his DYI's are superior.
#105
Interesting is a polite word. You'd think the thin metal bracket could be bent slightly if adjustment is needed. Let's hear what Unhingd has to say after he installs. Agreed on TheRock88. I've downloaded all his DIYs.
#106
JacksonvilleJag (09-16-2020)
#107
Good luck with this install.
DC
#108
Appreciate the positive feedback. And I will keep them coming as I get around to upgrading/repairing items. Glad they are useful. I like the DIY videos...But find them hard to use when you are trying to actually perform the task....Start....Stop...Start...Pause
DC
DC
Luck has nothing to do with it. Patience is the key. My options are to go through the wheel wells or the nose. The nose will take longer, but fitment will be more precise. I think I'll go that route. I might as well install the Paramount SC radiator at the same time.
#109
I installed the mina gallery intake tubes a few weeks ago expecting increased s/c whine. but unlike my expectation, it never increase at all.
Does anyone know why?
From the comments above, people said it increase the s/p whine.
I only installed the alluminum tubes w/o open filter. is this the possible reason that didn't increase s/p whine?
#110
Windows closed, exhaust valves closed. Shaky iPhone mount.
https://m.youtube.com/watch?v=pJV7OE...ient=mv-google
You only installed the tubes? or open filter too?
I use OEM filter box with mina intake and never found any increase on s/c whine when I installed it to hear that sound.
#111
#113
Hard to tell from your descriptions, but just changing the upper intake will have little/no affect on SC noise/whine.
The lower intake and filter have the greatest affect and also where the noise baffle is located. I have both and there is a definite increase.
Also, these newer Eaton - Roots SC's are not as noisey as the older types, or some other styles.
DC
DC
#114
#115
The reason that the SC whine remains muted after the upper intake installation is that the OEM baffled section of the intake remains in place and continues to effectively muffle the whine. The lower Mina intake eliminates that OEM baffle.
Yes, I am still using the OEM filter box. The only reason that you hear a bit of whine in that video is that the SC is spinning at close to 20,000 rpm with both the upper and lower pulleys. Even with the lower Mina intake tubes, I plan on using a filter element with similar construction to the OEM filters. open oil soaked filter elements do not offer adequate filtering protection.
#116
#117
#118
Thanks.
I also change the FIlter from OEM to BMC but your s/c whine come from your changing pulleys.
Do I understand well?
Without changing lower part of intake(filter section), I can't expect any S/C whine increase. but You don't recommend it because it won't function well you think.
#119
#120
I just got a clarification from Mina. K&N filters are 4 ply oil soaked, whereas the Mina filters are 6 ply oil soaked. Mina has recommended cleaning/re-oiling or changing the filters every 3000-6000 miles depending on road conditions. I’m still going to look for some paper/cloth filters that will fit, but feel comfortable using the Mina filters until then.
They come in all assortment of sizes and fitments.
I put one on my BMW M Roadster when I found the ITG foam oiled filter on the cold air intake starting to disintegrate.
Unhingd (09-21-2020)
