Mina Gallery Low Intake Tube Install No supercharger whine?
Hello all,
Just had the Mina gallery lower intake tube and filter installed and there is basically 0 supercharger whine. The box and silencer is removed. I'm not sure what it is.
Called Mina Gallery and they mentioned the YouTuber Sal'a Garage has the same issue possibly. He mentioned the symposer might be faulty.
Anyone else run into this problem and was able to fix it? I'm so saddened by this new issue that I came across. I kind of noticed that I didn't hear the supercharger whine with the older I take too, even at high RPM's.
Received 3,226 Likes
Hello all,
I have the V6 not the V8 but the effect of the Mina lower intake should be the same.
I went from stock - almost no SC whine
to VAP tune only (Stage 1) - a tiny bit more SC whine
to larger crank pulley plus VAP tune (Stage 2) - a lot more SC whine
to Stage 2 plus Mina lower intake - waaay more SC whine!
At all times in this progression I had the Symposer disabled with the simple "plug in the tube" method.
So maybe that's the first thing you should try - disable the symposer, only takes 5 minutes.
The Stage 2 VAP tune increases SC whine by a fair bit by changing how the SC bypass valve works - it keeps the valve closed more and closed sooner in the rev range than stock (open valve = more bypass so less boost and less whine).
The Mina lower intake (really two separate intakes and filters) increases SC whine a lot by deleting the stock baffles in the intake tubes. Those baffles cause a resonance which dampens the SC whine.
That is strange.
I saw this mod
cujet (10-02-2022)
When I spoke to the Mina Gallery rep he told me that's the opposite thing I should be doing since I did a quick google search and saw a few symposer delete threads. I forget the explanation so someone else could maybe chime in but he said I wouldn't want to delete it. Maybe it is a solution, but I'm not sure.
I saw this mod https://www.youtube.com/watch?v=YWS-...=Sal%27sGarage where he basically runs a tube from the inlet MAF straight to the cabin basically. The Mina Gallery rep told me that was another person's solution to the same problem I have with the intake's change still producing no supercharger whine. Requires some holes drilled but the end result is direct whine into the cabin. But, I've seen installs with just the lower intake and that should be enough to bring out the whine a lot so I want to try and tackle the initial issue of 0 whine because the intake install alone should be enough to bring out a lot more whine.
The Mina intake set up by itself should result in a large increase in SC whine so I have no idea why yours has not.
Why don't you at least try the Symposer defeat, nothing to lose (easily reversible) and only takes 5 minutes?
Maybe just maybe whoever installed the Mina set up didn't do it right and there are large air leaks?
Even stranger then!
The Mina intake set up by itself should result a large increase in SC whine so I have no idea why yours has not.
is there a way to tell it is leaking air? I wondered that myself but this install is pretty straight forward. I can try the symposer delete and see how that goes. I would like to try the inlet tube mod like above but I'm afraid I will still get 0 supercharger whine if I don't fix the root issue.
That intake tube mod looks fairly janky to me with a lot of time and effort (and maybe expense) for not a great result, and in the comments he even said he has deleted it now because it is too loud. I agree you need to find and fix the root issue before resorting to another possibly pointless mod, odds are that if you fix the root issue you will get all the SC whine you want with no loss of performance or drivability.
Maybe a smoke machine will reveal any leaks?
So I did put my phone up near the intakes with the hood open and recorded myself starting the car up and revving it. I hear the whine on my phone pretty well but it sounds like stock still.
When I drive with valves closed I hear some whirring noise when I accelerate at low speeds. Maybe it has something to do with my muffler delete but hard to hear it with the valves open so I don't notice it.
Maybe the whirring is a leak? I'm not sure. But I do know that the supercharge whine is there, it's just very faint.
I installed a full Mina Gallery intake and notice more supercharger whine than I did stock but to me it isn't a massive difference. Personally if I did it over I am not sure I would have added the intake. I think there is a debate on if it adds any hp or actually looses a bit of hp. I sat on mine for a year before I decided I was keeping it and putting it on. I will say that I get more sc whine if I am getting on it and very minimal if I don't have the peddle mashed to the floor.
Here is a video that demonstrates that. The only installation was the lower intake tube and filters and even with the windows up it is pretty noticeably loud.
I would not say it is crazy loud SC whine, and the exhaust definitely takes over. Here is a quick (not good quality) clip some guys took when I left a car show recently. This is an R with the Yellow Wolf Intake (similar to Mina). Just to give an idea of what mine sounds like from outside, under acceleration. I also have my symposer completely removed, but that would not affect the noise outside. Just FYI.
DC
DC
I would not say it is crazy loud SC wine, and the exhaust definitely takes over. Here is a quick (not good quality) clip some guys took when I left a car show recently. The is an R with the Yellow Wolf Intake (similar to Mina). Just to give an idea of what mine sounds like from outside, under acceleration. I also have my symposer completely removed, but that would not affect the noise outside. Just FYI.
Video Clip Here
DC
Video Clip Here
DC
I got an OBD2 sensor and I'm going to test the boost pressure and MAF sensor to see if the readings are correct.
Seems ok to me, but I do know that the SC only whines when under load. You tend not to experience the sound when only revving the engine or in low rpm ranges. I left the symposer connected and stock if that helps. The lowers on the Mina intake delete the sound dampener or whatever it's called on both sides of the intake (drive and passenger). The stock plastic intake has a lot more sound and temp control it seems. If you have a significant leak, the car is going throw a code and/or check engine light to you. Here is a boost curve that might help you compare if you haven't already seen it.
