Module flashing / programming communications failure
Hi!
Tried recently to update IPMB (Image processing module B), but run into an issue:
I've been trying multiple times and it always failing with the same issue.
I see that block/module functional and has no any DTC yet.
Due to that i've lost access to reverse camera (Camera system fault)
Any ideas what can be wrong? What can i do in order to resolve this issue?
Can it be related to equipment i use (was able to update PAM without any issues)?
Equipment i use:
The following modules failed download
Image Processing Module "B"
A failure occurred - Error code A01 Communications failure
Equipment i use:
- VCX SE
- SDD 160.3
Not sure any/many can help here. Couple of observations...
Appears your application is displaying something like Russian?
Also from your screens - Your car (or the car listed on the screen) is an XF(X260) not an F-Type, so maybe that forum can help you? This is a F-Type (X152) forum
If you are using "Cloned" software/hardware, that could certainly be an issue with not being able to access all modules and/or program them. Some clones are better than others.
Last...At a point in time JLR started using VCI/IDS and if you have a newer (I think 2018 on) car, some SDD version is likely not going to work, or work fully.
That's all I have...
DC
DC
Necromant1k (12-15-2021)
Last...At a point in time JLR started using VCI/IDS and if you have a newer (I think 2018 on) car, SDD is likely not going to work, or work fully.
DC
DC
Yeah, seems like i've created a thread somehow in wrong directory.
1) Yeah in Russian since i'm from Belarus. Just changed language in order to show an error
2) I have 2016 MY car, so i think SDD should be good, but i'll try different SDD version
Anyways, thank you for response
