So im on a quest to get more SC whine. I've searched through the forums using the search bar and have read all the threads i could find relating to intakes, but havent found exactly what im looking for.
Im not trying to get any more flow through the intakes , i just want more induction noise, I understand the SC on the F Type is made to be quiet, but near redline it sounds so good.
On the diagram below i think #3 & #4 are silencers for the intake system, has anybody tried removing them ? I know the Eventuri intake replaces it, but im not looking to spend $2k just for a slight noise increase.
Has anyone else done anything to get more noise from the SC/intake. I'm thinking of getting the lower pully from VAP, but that probably wont happen till later this year. I have also removed my engine cover, and that did help make it a bit louder
On the XF SC and XFR some have increased the blower noise a little by cutting off the resonators then plastiwelding a cover piece over each hole.
Two of them on the F-Type, on the under side of the top/centre pipes, number 9 in the pic and the same just under part number 8.
More supercharger whine would definitely be on my wishlist as well.
This is the second supercharged car I have owned , had a supercharged Lotus Elise around 8 years ago and replacing the standard airbox with a factory TRD one gave the most amazing whine., absolutely loved it
Wish Jag offered an alternative to stock, maybe the SVR team could develop something.
Call Chris at Mina Gallery --- he just made aluminum intake tubes for my f type and they eliminate noise restrictiors and look very cool and only cost a couple hundred $
If you want more information and pictures --- look up Mina gallery online and look up XFR ---- performance items -they look the same as for the f type --- he does show them for f type yet but they are available ------ mine were installed on my 15 f type r a few weeks ago ----- he has lots of other Carbon fibre parts also not shown online
Sorry, this doesn't make sense to me, I have both an XFR and an F-Type, and I can tell you that the induction tubing is completely different.
Here's a weird one for you. Drove my friend's 2WD 'R' extensively, it's the one in our exhaust videos. After we put a tune on it - supercharger noise increased substantially. And that was independent of actual boost levels. Going through the changes in the software I don't see a reason but then subsequently multiple customers reported the same after we tuned their cars.
Still don't know exactly why, but it seems to be repeatable.
It sure seemed like the supercharger was louder to me, but it's so subjective. And I was running it pretty had to test the tune. I need more time with it.
If you build something that will give us the ability to hear the whine better, put me in line for the first V8s run!
Not yet.. it's been raining and I want some dry pavement to get the pre-install video. Got a little video when it was dry, but the GoPro was too far out in the wind so the sound wasn't great.
There is - presumably - a bit of plumbing between the s/c outlet and the throttle body that dumps excess boost back to before the s/c intake. If that were disconnected and vented to atmosphere...
Kinda like a BOV on a turbo car ? Didn't know SC cars had those, anyone know where the recirc hose is ?
Interesting, I just ordered your tune for the V6S yesterday, hopefully I can replicate what your hearing
This would either cause A... a massive boost leak, or B... unmetered air getting into your engine and subsequently it running lean. Would not advise before truly understanding where that air is going.
