MPS4's v P-Zero in the rain - V8S
We all know how lousy the P-Zero's are, and how great the MPS4's are. I have been hugely impressed at the dry weather grip since putting them on. I drove in some pretty heavy rain today, and the wet weather performance is truly staggering, was able to drive in dynamic and get on the throttle (still being sensible and progressive). The P-Zero's were HORRIBLE in these conditions on a RWD V8S, would not have driven in dynamic mode with them on.
So... this is basically a call to arms for all RWD F Type owners. If you still have P-Zero's fitted you are missing out on so much of the cars capabilities and performance. Burn through them, or ditch them early if you can!
I know it will have been a commercial decision, but Jaguar should never have chosen the P-Zero as the OEM tire.
The Michelin 4S is just outstanding. Night and day difference from the Pzero. Came home from a dinner is moderately heavy rain with temps in the 50s. Highway drive with little time to get heat in them. Normally I'm a bit nervous with my RWD in those conditions. Not with the 4S, much greater confidence with just normal driving style. Never wavered.
I had these tires and the Michelin PSS on a Lexus IS350. The BFGoodrich were great for the price but the Michelins were noticeably better--they rarely slipped under hard driving whereas the BFGoodrich slipped a little when driving the same way.
ElloM8 (11-27-2017)
Indietor, if you're looking for a budget alternative to the MPSS, check out the Kumho Ecsta PS91. The tread pattern is conspicuously similar too.
I had them on my Mustang GT with ~450hp and was very confident in them. I suspect they're a little noisier than the MPSS, but night & day better than the PZero.
Why don't you have your local Michelin dealer custom order them from the factory? In fact, TireRack might even ship them to you. (Though it doesn't make much sense shipping them across the ocean twice).
I regularly commute on weekends between DC and New Hampshire - about 560 miles each way. Haven't had any issue with the PZeros in rain or heavy rain until the tread is worn down on the rears (about 20,000 miles). Then again, I only have an F-Type S. Even so, once the Pirellis wear out, I switch to Continental DWS all-season tires for a couple reasons: softer ride over less than perfect roads; and, better foul weather traction when the temperatures get low. Sure, I sacrifice some handling but that's what works for me. To each his own.
